K-Pro Knock Limit Table Question
Old Oct 18, 2012 | 04:02 PM
Metcalfe's Avatar
Default K-Pro Knock Limit Table Question
As you K-Pro users know, there is only one base map for a stock map. I am having a problem with the ignition in vtec. The car will not run the timing I tell it too. Turns out the knock Limit Table is retarding the timing. After reading the help file, it says to set the table to 0 in boost. Do I need to adjust the table outside of the boost map? There are quite a few negative values and I assume it is retarding timing at those spots also. How has everyone set up their maps? Screenshots would be nice... Thanks!!
Old Oct 19, 2012 | 06:58 AM
Metcalfe's Avatar
It appears that the tables are the same for almost every Kpro calibration except the AP1. I copied the table from the boosted cal from the 06 Dual Kpro. Seems to work fine now..
I am still curious how everyone is setting this up..
s2kslav
Dec 17, 2012 06:21 PM
crazysupratt
Jul 30, 2011 08:55 AM
S2Kart
Apr 2, 2008 05:37 AM
ChefJ
May 16, 2007 02:29 PM
MB
Sep 30, 2005 11:15 AM
