Kpro low/high boost switch
Old Jan 27, 2017 | 02:29 PM
FinestS2k's Avatar
Default Kpro low/high boost switch
Im in the middle of a full wire tuck on my turbo s. I'm rewiring many things considering the original owner had no idea how to make things look professional.
I have a hondata boost controller, found a thread pertaining to taping into the old Evap wires for the evap pump that's been deleted. My current wiring is to the ecu and it gross with wires everywhere.
Now my goal is to run a low boost setting and boost by gear and then a high boost setting with boost by gear also. I'm under the impression that this is possible with Kpro v4. What I'm looking for is a correct way to wire the switch for the ecu. What connector, what pin. A small paint picture or something will be most benificial. Has anyone done this successfully?
If someone could point to the correct connector on the ecu. (Like I said the previous owner did a epic hack job on the wiring for some of reason)
Jaspah
Feb 23, 2017 11:22 PM
08s2000CRbackinblack
Sep 19, 2013 03:07 PM
Aug 17, 2013 10:23 PM
liquidgsr
Oct 15, 2012 05:29 AM
jordannn93
Sep 29, 2012 09:46 AM
