low numbers with FlashPro tunned Kraftwerks
Old May 25, 2011 | 05:25 PM
  #21
06S2k07Si's Avatar
Originally Posted by EliteTuning
What is the i.d. on the exhaust? If it's less then 2.75, there's another issue.
As one example...not in MY case.
https://www.s2ki.com/s2000/index.php...f=142&t=817368
Originally Posted by bastanu
Thanks everybody . The car is stock, other than a Fujitsobo exhaust, I think its dual 60 mm. Several folks here are putting 370s hp and 240 torque on stock Ap2 s while others making 380s and 250s with some bolt ons. Mine is missing about 40 lb/ft of torque, so I suspect that something is wrong... I will try to get those details. I dont know to much about tuning but the exhaust smell rich ...
60mm mid pipe to dual 50mm split to exit (currently on my car)
Originally Posted by gernby
If you can create a datalog in 3rd gear from about 2500 RPMs to 7000 at full throttle, and send it to gernby2002 at yahoo dot com, I'll check it out. If your AF is in the low 10's, then it's definitely running too rich.
Agree...good advice!
Originally Posted by Swiftoy
Originally Posted by bastanu' timestamp='1305812429' post='20592078
Thx a lot. Today I pulled the error code and it was P2A00 something related to aaAF sensor range performance
That is a code for the primary O2 sensor you will need to replace it. There is a TSB out for this it affects all 06 models. I had to do mine recently so this is how I know. I highly recommend buying the sensor from honda as it is completely different from the one you will be taking out so there is clearly something different with the sensors. They are not cheap thats for sure 191.24 from Majestic Honda part number 36531-PZX-013.
I had the same problem and this solved it.
Originally Posted by cariza
Second: Check your knock (retard and sensitivity) maps in the flashpro. There is a big chance it may be reading engine noise even though its not knock and be pulling timing. I gained 10rwhp on my NA AP2 because the flashpro was pulling 8 degrees of timing in the know retard map. This was on the base map for Intake, header exhaust. Superchargers tend to produce noise and vibrations that trick the flashpro into thinking its knock making them pull timing.
Definitely check on this suggestion...I had to deal with this as well. (thin wall exhausts may cause this too)
Brian
Old May 26, 2011 | 01:48 PM
  #22
bastanu's Avatar
Thanks Brian, I was thinking of you when I mentioned ''others with bolt ons are making 250s torques"...I will retune the car soon, my tuner said the same thing, the vibrations are apparently read as knoks so the timing is off. The check engine light is gone for a week so I wonder if I still need a new sensor? The car needs to pass yearly emissions with OBD and visual exam so I do not know if a test pipe is a good ideea.
Old May 26, 2011 | 03:24 PM
  #23
06S2k07Si's Avatar
I noticed that even with the standard reflash that comes with the kit, the Vtec kick is smooth but mine is not, obviously that part needs to be worked on, but I dont know if would increase significantly the top end. I ll be very happy if it will make some close numbers to other stock guys. The financial effort to get FlashPro, IDs 1000 and tuning will be worth it only if I ll see some decent gains. I even got a new ACT clutch expecting gobbles of torque....
When I had the supplied reflash my VTEC was consistently at 4500rpm. I don't see why you shouldn't be at least 350whp or so (yes I know that dyno's vary). I've never had an OE header or cat with this kit so I cannot say about that. As for getting a high flow cat or test pipe, you could always just remove and re-install it for the inspection day etc. With the J's header, a 60mm TP and the Fuji exhaust I was making 370whp & 242 wtq on the reflash.
The 02 sensor...my CEL code came and went with the OE unit until I got the TSB replacement one...haven't seen it since.
As for flashpro...that was the best improvement that I've had of all of my HP mods. https://www.s2ki.com/forums/index.ph...age&img=680758
Brian
Old Jun 6, 2011 | 07:36 AM
  #24
bastanu's Avatar
Brian
Thx a lot, I ll get a new sensor. Not on the topic, but did you put in a fuel pump ? My installer is pushing for one saying I am starving at the top end ...
azride1983
Jan 22, 2011 06:23 AM
707S2K
Aug 29, 2008 08:36 PM
wildcardtrd
Apr 11, 2006 06:41 PM
Hamiy
Jul 30, 2005 09:24 PM
APEXSEAL
Nov 3, 2004 12:39 PM
