Readiness monitors (emissions check)
So my emissions check panel shows 4 incomplete readiness monitors, but also 4 readiness monitors not supported. Does this mean I don't have to worry about those ones? Not sure what "not supported" means.
You shouldn't have to worry about not supported, they either don't apply or are not tested. There are certain criteria that have to be met before the monitors are set to ready, there is information out there if you search for it. Do you have a CEL that you are trying to work around?
Well, I found that not to be the case. Readiness monitor at inspection said catalyst, evap, 02 sensor list as not ready. There are 4 on their list showing "not supported".
I know that 02 sensor and evap are showing checked last time I checked over a week ago and I had not changed them recently. Maybe I need to uncheck, turn car ignition off and on again, and recheck those values to start the cycle again. I'm really kind of guessing here because I am not able to find the "information out there" about how to start this process, as much as I've searched for it.
And the past couple days, the Calibrations window shows as blank! I can't see any of the items that should be listed in the left. I even have 'advanced' turned on. I've restarted Flashpro and the computer more than once with no change. I can't figure out why these aren't showing up and I can't change any of the settings until they do. Am I missing something here?
dan_bourne
Nov 20, 2014 10:20 PM
