Which is the right afr reading?
Old Jul 25, 2010 | 07:41 AM
robertjr314's Avatar
ALRIGHT, I GOT SOME NUMBERS BACK. I TESTED MY SENSOR PRIOR TO INSTALLATION, ITS A PERFECT O2 SENSOR. NO PROBLEM THERE. OKAY, SO AFTER MY FULL THROTTLE RUNS AT 8 PSI I WAS GETTING THE UNEVITABLE 10.50 ON THE UEGO. WHICH MEANS THAT IM WAY TOO RICH AND THE CORRECT AFR WAS THE "AFR" ON THE FLASHPRO SOFTWARE(NOT THE "AFR CORRECTED"). JUST WANTED TO LET YOU GUYS KNOW. SO, I DECIED TO UP THE BOOST TO 10PSI. NOW, I AM AT ABOUT 11.5. WHICH IS MUCH BETTER. HOWEVER, I PLAN TO TAKE HER EASY UNTIL MY TUNE IN SEPTEMBER!!!(LMFAO)
THANKS GUYS,
HOPE THIS HELPED!!
Old Jul 26, 2010 | 07:19 AM
Gernby's Avatar
Former Sponsor
Raising boost shouldn't lean out the mixture unless your tune is off.
Old Jul 26, 2010 | 07:53 AM
Well my tune is really Messed up.. I have been running 10.5 on 8lbs.. But, it seemed to lean out more when I raised the boost.. I still have the emanage on, not the flashpro.. I will be tuning it in the beginning of September..
zelig
Jan 3, 2014 08:02 AM
unethikl
Aug 22, 2009 01:22 PM
assalbert
Oct 8, 2008 01:20 AM
JoeyBalls
Apr 15, 2008 05:59 AM
Johnny Sack
Dec 11, 2005 09:48 AM
