VSA codes and FlashPro
Old May 11, 2012 | 03:19 PM
khaosman's Avatar
Default VSA codes and FlashPro
Hello!
My car recently started displaying the VSA warning light and occasionally the brake light. This happened after I had the car aligned. After doing some research, I checked the common culprits: brake fluid (fine), brake pad level (fine), and if the parking brake lever sensor was goofing up (also fine). I read somewhere that you can pull codes and to narrow down the problem... I was wondering if this was possible with the FlashPro. I plugged it in and did not find any error codes but was wondering if there was an option I was missing. Or do I need to take it to a dealership and have them look at with their diagnostic system?
Thanks
Patrick
Old May 11, 2012 | 08:29 PM
macr88's Avatar
The fluid has to be at the full mark or very close from my experience otherwise those lights will come on.
Old May 12, 2012 | 01:33 PM
khaosman's Avatar
Thanks Mac, I'll give that a whirl. It is just below the mid point but I'm probably due for a flush anyhow.
Old May 17, 2012 | 08:56 AM
khaosman's Avatar
Thanks again, that fixed it. Interesting that even above minimum line will trigger that. The more you know! (/cue Reading Rainbow theme)
Old May 17, 2012 | 09:03 PM
macr88's Avatar
You're welcome
s2kdarren
May 31, 2018 11:39 AM
DDonovan
Jan 20, 2013 12:44 PM
LenS2K
Nov 17, 2012 08:05 AM
barrett4bama
Jun 14, 2011 11:45 AM
slanguage
Jan 16, 2007 04:04 PM
