VSA codes and FlashPro
Hello!
My car recently started displaying the VSA warning light and occasionally the brake light. This happened after I had the car aligned. After doing some research, I checked the common culprits: brake fluid (fine), brake pad level (fine), and if the parking brake lever sensor was goofing up (also fine). I read somewhere that you can pull codes and to narrow down the problem... I was wondering if this was possible with the FlashPro. I plugged it in and did not find any error codes but was wondering if there was an option I was missing. Or do I need to take it to a dealership and have them look at with their diagnostic system?
Thanks
Patrick
Thanks
Patrick
s2kdarren
May 31, 2018 11:39 AM
barrett4bama
Jun 14, 2011 11:45 AM
