1lb of boost = how much HP?
Originally Posted by JoeyBalls,Mar 12 2008, 09:47 AM
yah, I don't think its really worth it to get a Boost controller, I would not want to go above 9 anyway
Keep in mind that the pressure number is an indirect indicator of the volume actually making it into the combustion chamber. Compare what gets into the chamber from a GT3076 @ 7psi vs. T518Z @ 7psi - completely different.
The AEM Tru Boost is nice because you just push the right button and it shows you peak boost you just pulled. You can have 2 boost settings in it, or just turn it off if you want to run off the WG spring alone.
Also, a headgasket only costs $295.
Originally Posted by Sideways,Mar 13 2008, 03:34 PM
I think what I said was clear. It depends on the base line and other factors. It is only an optimistic rough guide line.
ATO, I was seeing 360 rwhp at 7 psi with the high flowing Alaniz head, 16+ rwhp per psi.
I rather idolize your and JohnZ's work though.
robertm
May 24, 2014 11:09 AM
