planning on putting in engine with stock new OEM short block for mild reliable forced induction, plan on roadracing motor with S/C and then Turbo
i'm interested in 2.0 to maintain reliable 9000 rpm redline, what if any power disadvantage or other negative issues would you think arises rather than 2.2
a 2.2 will produce more torque at the same rpm as a 2.0 would. However, you won't be able to rev it as high safely as you would a 2.0. Try working out the type of power your looking to make in regards to the type racing your doing!
