38mm wastegate enough for 12psi
Old Feb 17, 2011 | 07:54 AM
rikhemi's Avatar
Default 38mm wastegate enough for 12psi
Have a inline pro kit stage 1 and wanted to go from 9psi to 12 psi. Also going to add a boost cutout for the exhaust to have a free flowing system. My concern is boost creep. I shoul be arous 400 to the wheels after I add these upgrades. Woold the 38mm wastegate be enough?
Also, I'm running 1 step colder plugs. Should I run 2 step now if my hp numbers are at 400?
Thanks,
Old Feb 17, 2011 | 09:51 AM
ChefJ's Avatar
yes and no.
38mm will be fine and2 steps colder is overkill.
Old Feb 17, 2011 | 10:22 AM
spectacle's Avatar
What turbo?
Old Feb 17, 2011 | 10:52 AM
rikhemi's Avatar
Turbo is a gt30 dual ball bearing..
Old Feb 17, 2011 | 12:27 PM
Marty Staggs's Avatar
If the 38 is working fine at 9 PSI, it will work fine at 12 PSI providing nothing else changes.
Old Feb 17, 2011 | 12:32 PM
UFfitz56's Avatar
38mm is fine. I ran a similar turbo on my STI (>410awhp) and it was perfect even at 26psi (different spring obviously).
Old Feb 17, 2011 | 12:42 PM
rikhemi's Avatar
Perfect..hopefully with a 3 psi increase and a open exhaust , I hit 400-425
Old Feb 17, 2011 | 01:53 PM
riceball777's Avatar
i run 9 psi fine with my revhard manifold and the tial 38mm with no boost creep what so ever. The most psi you run the easyier it is on the wastegate.
bigblueman1
Dec 30, 2015 09:24 PM
s2konroids
Aug 19, 2014 06:45 AM
robertm
May 24, 2014 11:09 AM
ideugene
Aug 11, 2005 09:55 AM
Project S2000
Oct 4, 2004 12:04 PM
