3mm headgasket
Originally Posted by Spec_Ops2087,Feb 18 2008, 10:35 AM
you'd be suprised then, the turbo is very small. Seems a lot of people were tuned for 9ish psi due to creep and the power was around 295-300.
Its unfortunatly, but thats the kind of power this kit makes; people have to understand that.
PS Is it not possible to buy a slightly larger Turbo later down the road?
Originally Posted by afwfjustin,Feb 13 2008, 03:39 PM
A: InlinePRO 3mm
B: New ARP
C: Used copper spray
D: 80-85 ft pounds with supplied moly lube
E: Did not retorque
F: Lasted 2500 miles at 11psi and blew the headgasket
B: New ARP
E: Did not retorque
Originally Posted by Sideways,Feb 18 2008, 12:11 PM
Oops, 80 to 85 is a little shy of what engine builders on the west coast are using. Out here with ARP studs they use 95 - 100 ft lbs with the lube. They also recommend doing a re-torque with the studs.
There shouldn't be any difference with the S2000. Any failures have got to be attributed to installation error.
Good thread... but does anyone actually know which ARP headstuds to use for the AP2 S2000 and the actual torque they recommend or are people still using the Prelude ones I read about earlier, and going from there??
http://www.kingmotorsports.com/category.aspx?cat=69
They are not the same part number as the studs for the Prelude. The studs will include the special moly lube from ARP as well as the torque specs.
i can get you some head studs for $155 - pm me
I would only use the headstuds - if going with a thicker head gasket you will loose that thickness of threads (3mil)- and remember you are going into an aluminum block. so studs allow more threads to pull from.
Originally Posted by fadiss2k,Feb 17 2008, 02:34 PM
Wouldnt you make more power with a 3mm headgasket than a stock one bc you can go higher with how much boost your run?
Def not with the gt30 on the prototype setup I made. I was able to almost max out a gt3076r on pump gas (93 octane) w/ the stock motor.
Simply put, when you add the 3mm HG, you will have to run more boost to make the same power as you would w/ the stock HG on lower boost.
Originally Posted by Spec_Ops2087,Feb 17 2008, 03:00 PM
Great tuner or not, I wouldn't trust 18+psi on stock compression, no other turbo car runs such high compressions.
Dont base your claim on static compression. thats just one part of the equation.
boost pressure isnt everything. pressure vs. flow changes drastically depending upon the turbo setup.
there isnt a magic boost pressure that limits you. There are much more factors involved.
