3mm headgasket
Old Feb 17, 2008 | 07:57 AM
  #31
2QYK4U's Avatar
Originally Posted by afwfjustin,Feb 17 2008, 09:49 AM
Joey, you can run more than 8 psi on stock hg - many people have gotten away with nearly 10psi with turbo and a good tune. I'd get it looked at every time the weather changes drastically though (summer/winter) to be safe.
I am running 13psi on stock hg.
Old Feb 17, 2008 | 09:01 AM
  #32
Spec_Ops2087's Avatar
Originally Posted by JoeyBalls,Feb 16 2008, 11:35 PM
hm I wonder if after a Test Pipe the Boost would drop a little. Just wondering if buying a Boost controller is worth it, if 8psi is the safest/highest PSI I can go on a stock HG, I was thinking maybe 9 with a good tune, I would imagine 7PSI to 9PSI is a fairly good amount ot HP?
a testpipe will raise your boost due to the reduction in backpressure.
On a greddy kit, 10psi is about 300hp.
Old Feb 17, 2008 | 09:50 AM
  #33
freshs2k's Avatar
10 psi is the most on the stock headgasket. Whats the reason they're blowing? Is it the psi/power or it just the install difference? I've seen other people doing 18+ psi and fine then 14psi and blowing them. Im getting ready to do my commetic 3mm headgasket. I know there is a some little stuff that has to be done correctly to get the proper seal/ install.
Old Feb 17, 2008 | 10:34 AM
  #34
fadiss2k's Avatar
Originally Posted by mase1,Feb 17 2008, 10:24 AM
There are a lot of HG failures.
It doesnt make sense to me to use the thicker HG, All that work, and extra money, lower performance, and still a risk of the thicker HG failing.
Spend the extra money on a good tuner.
Wouldnt you make more power with a 3mm headgasket than a stock one bc you can go higher with how much boost your run?
Old Feb 17, 2008 | 10:35 AM
  #35
fadiss2k's Avatar
When are you installing yours? Let us know how you did it.
Old Feb 17, 2008 | 11:00 AM
  #36
He's implying less horsepower vs a stock compression car.
Great tuner or not, I wouldn't trust 18+psi on stock compression, no other turbo car runs such high compressions.
Old Feb 17, 2008 | 12:00 PM
  #37
TheCarGuy2021's Avatar
+1
I'd rather have a blown head gasket as opposed to engine failure.
Old Feb 17, 2008 | 12:35 PM
  #38
kutsujula's Avatar
Shit's so confusing, people say dont go over 8psi or 10psi on stock compression then others saying there running 12+. I plan on running 10psi stock head gasket on the full race stage 2gt and hope to make 375-400whp reliably. We'll See
Old Feb 18, 2008 | 07:41 AM
  #39
afwfjustin's Avatar
I think it'd be more than 300 on 10psi - I mean people are getting 285 on the "stock" 7psi spring. There's no way you'd only get 15hp with 3psi. I'm guessing 10psi on greddy would be in the 320 range.
Old Feb 18, 2008 | 09:35 AM
  #40
you'd be suprised then, the turbo is very small. Seems a lot of people were tuned for 9ish psi due to creep and the power was around 295-300.
Its unfortunatly, but thats the kind of power this kit makes; people have to understand that.
