4.5inch pulley for vortech
Old Nov 4, 2005 | 11:19 AM
bullet1123's Avatar
Default 4.5inch pulley for vortech
I called ASP to order a 4.5inch pulley for a a vortech SC I will be installing in few weeks, and they gave me a choice of steel or aluminum????? Which one are you guys using, and which is better? / why? Im looking to get 9-10 lbs of boost (according to sideways a 4.5" pulley will do that)....i would assume the aluminium is lighter and the better choice, but maybe theres something im not thinking of???
Thanx
Joey
Old Nov 4, 2005 | 12:32 PM
Venomous S's Avatar
go with aluminum, a bit lighter to spin, it wont make a ton of diff however.
Usually they recommend steel pulleys if I recall correctly anything 3" or smaller because of belt slippage. This is as quoted by ASP on a phone conversation months ago.
Old Nov 4, 2005 | 01:08 PM
Ztec's Avatar
I agree with Venemous on this one! I went w/ Steel at ASP's reccomendation with a 3 inch pulley but you should be fine with Aluminum for your pulley.
Old Nov 4, 2005 | 04:24 PM
SstoneS2k01's Avatar
What else did you get to run that pulley? AEM EMS and injecotrs? I also would like to raise boost to 10 lbs.
Old Nov 4, 2005 | 04:32 PM
GoFaassttt's Avatar
yes, you will need larger injectors and an engine management system. You will will also need a good tuner.
Old Nov 4, 2005 | 10:00 PM
bullet1123's Avatar
I have an AEM 1052U and 650cc injectors.....
joes sled 2000
Jun 5, 2017 05:59 PM
martus2k
Jun 3, 2006 11:41 AM
johninator
Sep 17, 2005 03:03 PM
jwkim
May 12, 2005 12:46 AM
dave22
Jan 24, 2005 06:53 AM
