700whp or Bust
Originally Posted by tunedbycft,Jul 3 2010, 01:59 PM
If it was my car I would not run a Wiseco piston for a car that is going to make more than 650whp. By experience I broke an "Upgraded wrist pin" from Wiseco making 720whp.
If it was my car & im on a budget, this is what I would run:
-Mahle 9:5:1 comp Coated forged pistons (for Stock Sleeves) Est. $690
-Brian Crower HP Rods Est. $600
-ARP Head studs Est. $160
-New Bearings Est. $130
-OEM Head gasket Est. $80
-Upgraded Dual Springs & Ti-retainers kit Est. $380
SubTotal: $2040
And you got yourself a 700whp motor!
Unless you have the $$$ for the sleeves & that will be a different story.
Thanks,
Fernando @ Kings Performance
SubTotal: $2040
Thanks,
Thanks.
Originally Posted by Spoolin,Jul 3 2010, 09:39 PM
I think they meant to leave the tranny in the car but drop the k member down with the engine still on it, not pull the engine from the top.
If this were on a lift, I'm doing this on a garage floor.
Originally Posted by siadam,Jul 4 2010, 12:42 AM
That does me no good, then I wouldn't be able to get the motor out from underneath the car?
this is what i used when needed to replace my clutch which is pretty much the same thing as removing the motor just w/o an engine hoist
https://www.s2ki.com/forums/index.php?showt...0&#entry1036057
I just recently did this. I lowered sub frame bolts per the service manual and pulled tranny off and lifted motor from the top I did this in my garage. Its not so bad. Good luck. Be careful not to damage cam sensors.
You could do it that way to. I was able to loosen the top trans bolts from the engine bay and slide the trans out it was pretty simple I did it by myself. I just didn't want to undo the steering column and suspension cause you have to get everything re aligned both ways. Ball joints as well.
