aem 2step
Old Apr 24, 2006 | 06:34 PM
TJTURBO's Avatar
Default aem 2step
hey guys this weekend i was trying to get my 2 step working and i couldn't get it to work. can anybody help me? do we need a clutch switch or not?
Old Apr 24, 2006 | 08:14 PM
timg's Avatar
No clutch switch is needed.
Run the 2 step rev limiter wizard- if you're not running the latest version of the software, consider upgrading. Many new features have been added including this one. I can tell you how to do it on the earlier ones also though. Play with the settings from soft to hard cut. Pick the one that works best for you.
Make the settings in the 2 step rev limiter options:
Switch is always on
2 step fuel cut - set this a few hundred RPM higher than you would like the 2 step to be set
2 step ignition cut - set this where you would like the 2 step to be set (max)
2 step ok below VSS - 7-10 mph will work
2 step retard rev - start this where you would like the computer to begin retarding timing
If you have any questions, the AEM help in AEM Pro has a great document on the 2 step rev limiter. I'll also try to help however I can.
Tim
Old Apr 25, 2006 | 03:19 PM
TJTURBO's Avatar
thanks again tim it's nice to have someone like you always trying to help, but i tried it yesterday and it didn't work that's why i was asking if i needed a clutch switch. but since i don't need a switch i just need to play a little more i had my setting like this:
Switch is always on
2 step fuel cut - 4500 rpm
2 step ok below VSS - 7-10 and even 100 lol
2 step retard rev - not sure where it was maybe 4000 rpm
maybe i have the wrong version
oh and by the way i dont know if u remember talking to me about a topmount manifold??? well i just got my lovefab and a gt35r 4inch inlet 82a/r and a 60mm hks wastegate... so i will be selling my ultimate racing manifold, t3/t4 57 trim downpipe and 38 mm wastegate anybody interested pm me...
Old Apr 26, 2006 | 07:31 PM
timg's Avatar
Sounds like fun! I love top mount S2000's. I'm glad to hear that you've got it running.
I'll check my map and see what settings I'm running. If I don't have it with me, I'll dump it from the car when I get back home Saturday. I got it to work, but did have a bit of difficulty at first and it's still not fine tuned. When I upgraded to the new software/firmware, it was setup, but didn't work until I redid all of the settings.
Good luck
Tim
Old Apr 22, 2008 | 06:29 PM
duff0000's Avatar
anyone else have there 2 step working on there S?
dan_uk
Oct 4, 2014 01:35 PM
camuman
Oct 1, 2008 06:45 PM
Tjs S2k
Nov 26, 2007 05:37 PM
Spec_Ops2087
May 14, 2007 05:08 PM
fperra
Nov 3, 2005 04:30 PM
