AEM EMS V2 not getting power
Old 05-04-2016, 01:50 PM
FoBi3s's Avatar
Default AEM EMS V2 not getting power
Hello guys i recently been having trouble with my kraftwerk sc with AEM EMS 2. It was running fine for a few months but now it start acting up. AEM EMS wouldnt connect when i turn key to on. i sent the unit back for full inspection and they said everything is GOOD.
so now when i need to turn on the car. i have to disconnect battery and reconnect. when doing so, it give power to AEM EMS and fuel pump would prime and start.
have anyone experience this and how to fix it?
Old 05-04-2016, 02:33 PM
JUSTINTHECOASTIE's Avatar
Check your connectors, be sure none of your wires got de-pinned. Check power wire, its source, and ground.
Old 05-04-2016, 05:59 PM
FoBi3s's Avatar
i also try connecting the factory ECU and everything fire up just fine.
Old 05-04-2016, 06:36 PM
try using a different usb connection wire
Old 05-04-2016, 06:51 PM
FoBi3s's Avatar
USB connection is not a problem. the problem is that AEM EMS only activate whenever i disconnect and reconnect the positive battery and it would only fire up ONE.
Old 05-05-2016, 04:45 AM
Well, now you have to fix that. Check the voltage of the battery and the power line to the ECU
Ek_Jak
07-20-2010 01:50 AM
drdamian
03-23-2009 04:01 PM
superchrgd_AP1
08-24-2008 09:53 PM
03S2KAY
11-16-2004 02:42 PM
Hitman
11-04-2004 02:52 PM
Quick Reply: AEM EMS V2 not getting power
