AEM V2 Flex Fuel Cold start help
Old Jun 9, 2016 | 09:59 AM
nMeOnE's Avatar
Default AEM V2 Flex Fuel Cold start help
Does anyone have a good flex fuel cold start table that they can share?
I just started switching my car to the corn juice and it needs to be cranked over a couple of times before it starts like it does on 93. Basically cranks over and dies, then after the 3rd or 4th try it would idle. When its warm it starts perfectly!
I tried increasing my initial crank pulse and that barely helps. I'm sure i'm missing some other settings to adjust.
Setup is SOS SC with 3" pulley 15-16psi
ID 1300
Walbro 485
AEM V2 for DBW
AEM FPR set on Base fuel pressure
Old Jun 13, 2016 | 06:38 AM
nMeOnE's Avatar
no one has any good tables for Flex Fuel Cold starts on the s2k?
Old Jul 5, 2016 | 08:14 AM
nMeOnE's Avatar
nothing?
Old Jul 5, 2016 | 08:55 AM
liquidgsr's Avatar
My cold starts aren't very good either. My car revs to 3k then drops down. I am running ID2000s and looking to switch to 1300s.
Old Jul 6, 2016 | 06:57 AM
joels2k's Avatar
I'll give you guys my data when I get home. i'm running ID2000 on e85
Old Jul 6, 2016 | 11:01 AM
herecomesboost's Avatar
ID2k's // Flex
Old Jul 7, 2016 | 07:07 AM
nMeOnE's Avatar
After reading the Evo forums for their E85 tuning strategies and couple other sites . I was able to get my 1300 to startup on first try. No more 5-6 cranks! It still needs some fine tuning in terms of starting like a stock car but it is 100 times better then what it was. I use to have to crank so much that my battery voltage would drop and i would have to charge the battery.
My currently Ethanol Content is 84% and i'm running ID1300.
this should be a good starting point if you need it.
Old Jul 7, 2016 | 07:17 AM
nMeOnE's Avatar
Originally Posted by herecomesboost
ID2k's // Flex
how is your startup on the ID2000? start like stock or close to it?
Old Jul 16, 2016 | 05:57 PM
sohc_mshue's Avatar
You need to hose it down with fuel on the initial crank pulse when cold
nMeOnE
Jul 5, 2016 08:14 AM
blink962
May 21, 2015 04:36 PM
AP1GroceryGetter
Sep 13, 2014 01:11 PM
KiNgKoNg723
Mar 23, 2014 06:30 PM
s2konroids
Feb 15, 2014 01:07 PM
