aem watermeth problem
i have a code 2 error on my aem meth kit, its between the pump driver and the coontroller, y try test button but there no spray , some of you have ever get this problem? i have 12 volt on my orange wire and on my batterie wire
[quote name='japancrx90' timestamp='1341701455' post='21841706']
anyonw had this king off problem, the kit run good for 6 month, can my pump can be defect? controller?
Apply ground to the black wire on the pump, if it sprays the pump is good. Then go to the controller. Apply ground again to the pump wire. If it sprays, the wiring is good. Only thing left is a faulty controller. Call Aem's tech line, they provide excellent customer service. My flow sensor failed after about 2 months, I sent it in and they fixed it and sent it back in about a week. No charge. If your controller is bad check your wiring carefully. Bad grounds will kill the pump driver quickly.
humm i chek it completely tonight, my pump was srcap, my bearing are all going, they make noise when the pump turn, i open the pump, there was a little spring that was broke on the brush off the motor, i finnd little spring that make the job, but i can ear the bearing are so loud, i open the other side off the pump, there was corrosion on the bearing, i only run distilled water, the pump vas the new black aquatec,only used 6 mouth, those pump are not very tuff i think
i twist a little spring, i turn again , but the lower bearing is scape i oiled it, i order another pump, but i want to drag racing next sunday, if i dont have my new pump i will run the old one , scuse me for mybad english
Just mod the tune for no meth and run safe till the new pump gets in.
sbrodacz
Mar 23, 2009 03:36 PM
