AFR value not changing in aempro HELP!
Old Oct 14, 2012 | 09:45 AM
seansniper's Avatar
Default AFR value not changing in aempro HELP!
I have the wideband hooked up and I have it grounded to the bolt that you pull to pop the hood open. The AFR's read fine on the gauge however in aem pro the AFR does not move at all. The only way I can get them to change is by changing the gain and even then they just stay they dont even move. I have tried changing the units to something else and back and still can not get it to move in the software. Anyone else encountered this issue or know what I can do to fix it?
I first had it spliced into the c16 and read around and a few people said they had problems when they spliced it so I cut the wire and connected them together and it still has the same issue
Old Oct 14, 2012 | 05:55 PM
seansniper's Avatar
It seems as though when I start the car and look at the voltage the 02 sensor is putting out in the aempro software , it stays the same or will change by +-.02 hence why the air fuel is not changing really at all. Anyone know what would cause this?
Old Oct 23, 2012 | 03:58 PM
S2KBAR's Avatar
Having the same problem, please advise.
Old Oct 23, 2012 | 06:25 PM
camuman's Avatar
What box are you on? 1052?
Did you follow aem instructions to send signal in?
Old Oct 24, 2012 | 02:57 AM
timg's Avatar
Have you used a multimeter on that wire to make sure the voltage actually is changing?
Tim
JspecVtec
Oct 4, 2012 01:26 PM
deepbluejh
18
Jun 8, 2011 08:21 AM
lzybum
May 16, 2010 07:15 PM
zeroptzero
Dec 20, 2009 07:21 PM
hyperpm
May 26, 2003 07:15 PM
