Another AEM FIC user
Thanks for the info suzuka.
I finally got the new rear so I can do some more tuning but I am having issues. I was in a large parking lot working on my tune I noticed I had some really bad lean and rich spots just driving around normally. I played with it for like 30 minutes and got a nice tune. I shut the car off turned it back on and my tune was crazy lean. Is this the ecu learning or what and is it going to do this every time I turn the car on and off? I heard of people doing some kind of relay trick to the ecu so it wont learn but I dont know what the trick is and if I do it and I am on a 2 hour drive is the ecu gonna learn and then screw up my tune until i shut the car off and on again
i think that's the toughest thing about tuning with this system. You have to make as small of an adjustment with everything as possible. The F/IC has to work with the ECU and not fight it.
Hopefully in a very short period of time I will be able to give you more insight on it. I am shooting to get to the dyno this tuesday.
Well me and my fiance spent an hour and a half tuning my car yesterday. I must have done 120 pulls. She is sitting in the passenger seat with the laptop making adjustments as I tell her its so much easier than doing it myself. I shut the car off and on a few times and my tune seems to be getting much smoother and leaner which is great because I was pig rich before. Car is accelerating smoother and making pretty good power. It still needs more work but I am getting there. Maybe I will drive it some today to see if my tune is still good.
So I took it out today and that nice driveable car I had is gone. WOT is still spot on I run right around 12.0 to redline. Driving around town suckssssssssss. As others have stated one day you tune and its perfect the next its all screwed up I have horrible lean spots at partial throttle that cause the car to bog and buck. Those lean spots were not there yesterday. Do I just keep tuning those out and the computer will eventually give up or what?
At least it seems to be consistant, just not in a good way
I was curious as to if the FIC could be tuned out for say anything under VTEC because they stock ECU handles that fine. The only prob I still have with mine is that pig ass rich hops occasionally with partial throttle between 4-5k rpm. Under boost my AFRs run about a 10.8-11.2. Other than that its fine, but its going to be some time before I get injectors and pull the ESM and FPR.
