Any Options to Quiet the Fuel Pump?
Old Apr 12, 2011 | 08:46 AM
Anpaul's Avatar
Thanks a ton.
I'll try to figure out the thread tonight and then order something in.
I feel like they'll make quite a considerable difference.
Old Apr 12, 2011 | 08:49 AM
redboost10's Avatar
yes they do. are you use the aeromotive moutning bracket for that pump?
Old Apr 12, 2011 | 08:55 AM
TerminatioN's Avatar
Turn the stereo up. That will fix the problem.
Old Apr 12, 2011 | 09:44 AM
Anpaul's Avatar
From what I can tell, the Aeromotive is just bolted to the chassis.
I bought the car after the modifications were all done, so I'm trying to iron out a few things like this.
Old Apr 12, 2011 | 09:48 AM
redboost10's Avatar
ok i see, sorry i was thinking of the a2000 pump which is a different style. yeah the a1000 has those built-in tabs on the body of the pump which will make it easy to install these vibration mounts.
Old Apr 12, 2011 | 09:52 AM
Anpaul's Avatar
That's what I was thinking.
My only concern is that if the mounts are too long thick I'm going to have even less clearance between the pump and the ground. It makes me nervous as is.
Old Apr 12, 2011 | 09:56 AM
redboost10's Avatar
.5" is the shortest they have, if another half inch is going to be a problem, you can use some rubber washers between the pump and chassis to tone it down a bit and not lose that half inch of clearance
Old Apr 13, 2011 | 11:10 AM
jzz30's Avatar
how much power are you making that makes you need the a1000?
Old Apr 13, 2011 | 11:16 AM
Anpaul's Avatar
The car was tuned on C16 to make 693/527 by the previous owner.
I'm going to be retuning it this upcoming Monday for a DD tune on 10-12 psi.
ahrmike
Sep 8, 2012 08:09 PM
PUNCHIN-IT
Apr 9, 2010 07:22 AM
jwkim
Apr 17, 2005 08:11 PM
pete_keeling
Apr 19, 2002 07:10 AM
