ARP headstuds
Old Jun 2, 2009 | 02:51 AM
bradshit's Avatar
Default ARP headstuds
Hi , just want to know if I just take one and one headstuds of the
motor and replace them with ARP! is that a stupied thing
or should i take of the complete top and put a new headgasket on and chek the top ??
Old Jun 2, 2009 | 03:20 AM
AusS2000's Avatar
Depends what you're trying to do. If your head gasket is fine just replace one at a time. If it's blown do a complete head gasket job.
Old Jun 2, 2009 | 05:51 AM
m R g S r's Avatar
I would just replace the HG anyway
Old Jun 2, 2009 | 09:55 AM
bradshit's Avatar
the engine is running good im gonna run turbo so thats why asked
what people here normaly do ...
if they take of the top ( to chek the top if it is straight , and if gasket is good )
or just leave it on and just put the arp studs on !
Old Jun 2, 2009 | 12:03 PM
TRBOKEV's Avatar
If your going to run the factory head gasket leave it alone! The stock studs are more than adequate.
Old Jun 2, 2009 | 06:22 PM
honda9krpm's Avatar
The stock bolts are quite good for the amount of boost you can safely force into the stock engine.
Old Jun 2, 2009 | 06:26 PM
AusS2000's Avatar
I agree. If it ain't broke, don't fix it.
I'm at 22psi. Mine broke, so I fixed it.
Old Jun 2, 2009 | 09:40 PM
honda9krpm's Avatar
Aus, yes but you would not be able to run 22psi with a stock compression...well on pump fuel anyway.
Old Jun 3, 2009 | 05:16 AM
Quivers's Avatar
Banned
I have a similar question, my motors already built with a cometic gasket. Can a swap the studs so I dont have to buy a new gasket?
Old Jun 3, 2009 | 08:56 AM
2jztuned's Avatar
yes you can swap the bolts out with the studs. you do not have to remove the head.
WRX2S2K
Dec 31, 2012 09:49 PM
TRBOKEV
Dec 21, 2010 02:22 PM
RedLineS2k10
Mar 19, 2010 07:01 PM
SuzukaS2K
May 16, 2003 10:00 AM
Elements
Feb 17, 2003 07:50 PM
