ARP stud install
Old Apr 20, 2008 | 06:56 PM
PeanutButter's Avatar
Sweet, love when the mods go thorugh and change titles.
Old Apr 22, 2008 | 07:27 AM
PatS4P's Avatar
Banned
Just got off the phone with ARP. 80 ftlbs with the moly. I mentioned the the 86-90
ftlbs. PB had on his paper and he said incorrect
Old Apr 22, 2008 | 07:31 AM
3ngin33r1's Avatar
No kidding. I was looking back at this and thinking to myself, I never posted to that one, then I read my post and was thinking, WTF?
Old Apr 22, 2008 | 08:13 AM
ya@inlinepro's Avatar
I don't think he is asking about the NUTS onto the stud.
He is asking what is the torque spec of the stud into the block.
The paper should tell you to screw the stud in by hand and MAKE SURE you do not mess the threads up inside the block.
Once you get to the bottom, ARP says to unscrew them a little bit so its not resting on the top thread. They you torque it down with the nuts to the proper torque spec.
Old Apr 22, 2008 | 08:23 AM
The back of the box, the paper work and the rep at ARP all told me 85-90.
We did 85 with a small extension, so im hoping that backed off the torque a few lbs.
Old Apr 22, 2008 | 08:25 AM
The ARP rep did not mentionbacking them out at all. He said hand tight, which most people can torque to 5 ft lbs with thier own hands,
Old Apr 22, 2008 | 10:42 AM
TheCarGuy2021's Avatar
When threading the studs into the block you don't want them to be too tight. I used an allen key to thread them in and out a few times to spread the moly lube. I then "finger" tightened them, as I used my pointer finger and thumb and gently screwed them in until they just touch the bottom but are still loose.
Old Apr 22, 2008 | 11:06 AM
why would one one loose studs?
Old Feb 23, 2009 | 05:41 PM
STREETWERKZ's Avatar
i know this is an older thread, but i couldnt find any information under search or google. please respond with the correct answer guys...
does anyone know if you can install these studs into the block with the motor still installed? as you all know how hard it is to pull just the VC off of the motor with the engine in the bay than i would assume the head would be a little/ or alot harder to install.
im getting my head back from alaniz pretty soon and i've been purchasing parts to get the head install back in order without any major problems.
ARP studs or OEM bolts???
Old Mar 2, 2009 | 08:50 PM
well, i guess im gonna just try it. got the head back from alaniz on friday. if all else fails, i can buy new OEM headbolts.
cmn
Jul 26, 2012 11:08 AM
scai103
Sep 15, 2011 11:34 PM
NoRegrets78
Jul 1, 2011 03:50 AM
lowandsmooth
Aug 11, 2008 06:37 PM
SDosMil
Jul 7, 2002 12:16 AM
