Awesome METH leaking everywhere :)
Old Nov 25, 2008 | 04:59 PM
  #41
jwa4378's Avatar
My brother-in-law had a C5 Z06, and that thing felt like a MONSTER compared to the S2k (size-wise... it was about a fast as I am now...).
I just could not get over having to shift at like 4500-5000RPM... that is a SHORT pull! I also like our gearbox a LOOOOOTTTT more! Straight-sex compared to GM's numb-boxes.
John
Old Nov 25, 2008 | 05:42 PM
  #42
JoeyBalls's Avatar
John
hahaha yeah when I drive the Viper it feels like the gearbox is a Baseball bat in a Garbage can, the throw is huge the shit knob is high
Old Nov 25, 2008 | 07:23 PM
  #43
HMFIC's Avatar
i like that analogy joey! hahaha
Old Nov 26, 2008 | 05:12 AM
  #44
RichV's Avatar
Originally Posted by EngineerX,Nov 25 2008, 03:39 PM
Yeah! If it wasn't for Joey, we wouldn't have as much info on the Greddy kit.
His posts are informative, he's trying new stuff and he shares with the rest of us. He's never said he's a Greddy turbo kit guru, just a fellow enthusiast. That's what these forums are for anyway. If you have a 600whp S2000 with zero problems, awesome- you shouldn't be looking in these forums then.
Regarding Meth kits:
It would be prudent to invest in a good water injection system that incorporates a failsafe mechanism.
There are several companies that offer failsafes.
Basically, you can revert to wastegate spring pressure by wiring the failsafe into your boost controller.
here's one example - I use this system in my Subaru STI
The only drawback is that these systems are more expensive (Aquamist is about $700) and more complex to install. But well worth their price when your boost goes to spring pressure thus saving your engine.
http://forums.nasioc.com/forums/show....php?t=1151715
When you use water inj. You have to pull fuel and advance timing because meth will induce richer AFR's. That's how you gain hp & Tq. But if you remove the meth, depending on how much fuel you have pulled and how timing you've advanced, then bad things may happen. That's when failsafes come in handy.
When you get that Viper, you'll have another type of issues: lack of traction, super-low mileage, no enjoyment from working on your car @ 20F, .......
Amen on all points. I have learned a lot from Joey, even though I have never met him! I am back and forth on Meth. I will just continue to follow Joe's car to see how the Meth turns out!!
Old Nov 26, 2008 | 05:31 AM
  #45
sparrow's Avatar
Old Nov 26, 2008 | 06:18 AM
  #46
8kGoodENuff's Avatar
Joey,
Just ignore the idiot comments that people have. Someone here (remains nameless) is bashing you about not being a mechanic and that his kit is this and that but throw him in a cockpit of one of the planes you fly and tell him to fly it and see how he does.
The point is that it's awesome that you're sharing all of this with us so that we can soak it all up like a sponge and learn ourselves about these issues.
Instead of wasting his breathe being a critic, why doesn't he just help a fellow member?...
Andre
Old Nov 26, 2008 | 07:47 AM
  #47
GDM S2K's Avatar
U get the TPS sensor
Old Nov 26, 2008 | 07:59 AM
  #48
chairmnofthboard's Avatar
Originally Posted by JoeyBalls,Nov 25 2008, 11:29 AM
Yeah I am 12PSI but have it set to around 11.5ish and I went with METH more for an additional safety measure/detonation suppression then for the extra power
Hmm good point. i thought about running that kit too. but haven't had any detonation issues so I figured why complicate things.
How do you fill the tank if it's behind the fender?
Old Nov 26, 2008 | 07:21 PM
  #49
JoeyBalls's Avatar
I did thanks a million man, the TPS light is back on but I think I know what it is. When I pulled out my TPS it was all wet inside from the METH, I am going to dry it this time and replace and see what happens. I put yours in and it ran great for a week now the same thing. I will have to order a new Throttle body, or maybe put some silicone on the inside of the sensor to prevent moisture from getting to the contacts.
Thanks a million.
The way the sensor is I believe it does not get ruined if the wet because what is getting wet is the metal of the TPS sensor and the Metal of the TB, so that is what is causing whacky voltage, I will take it off and dry it out, put back in and see what happens
CHAIRMENOFTHEBOARD : I use the Windshield Washer fluid resivour , so fill like you would the washer fluid
Old Nov 27, 2008 | 04:55 AM
  #50
GDM S2K's Avatar
NP lmk if you need anymore help
