best 1/4 mile time on stock diff
Originally Posted by JO TECH,Sep 24 2008, 05:45 AM
1.55
Nop!!!!!
stock diff nop......
Hey i have a lot of exprince in drag racing.... 1.55 on street tire stock rear end... naaaaaaa
Matt Keller cut 1.48 with slick ran 9.2
Nop!!!!!
1.55
Nop!!!!!
Nop!!!!!
Originally Posted by Revenge,Sep 23 2008, 10:58 AM
I would agree, I think I may lean to the 4.44 though, so no help will come from spings and lowering tire pressure.
I enjoy 4.30's myself but have run 4.44 when N/A and found them to be very good for that power level. If you were making anymore power at all I would say pick up some 4.30 Mazda gears/or go back to stock 4.10. You can always try what I have done which is cheat sort of speak and run a different overall wheel tire size if you want to experiment and don't want to blow a big wad with every gear change. Check the gear calculator floating around and run simulations to cross reference what tire size equals a rear end gear etc. If you really want to maximize your cars potential in the 1/4 you need to understand the basics. This is a good place to start. The basic idea is to pick the trans gear best mated to your power level you can pull, you want to finish at close to redline as possible to maximize, 4th gear for example, then find a rear end gear to fine tune this power level vs rpm in your gear choice. Hope that makes sense. Once you start paying attention to what gear your in and at what rpm at the finish, you then have a basis for which direction you need to go to maximize your trap speed/time at your power level. Doesn't do you any good if you cant get traction of drive the car properly however.
devinfox
Apr 28, 2009 06:39 PM
