best map sensor?
Old May 22, 2010 | 01:09 PM
hondabim's Avatar
Thumbs up best map sensor?
hello boosting freaks!
need some info, what map sensor are you useing? and what is the best one to go for?
i am running a 1052u and going to push 20 psi.
also where can i get a tuner toys adaptor from
thanks
Old May 22, 2010 | 01:30 PM
EK9MAX's Avatar
hondata. plug and play. Plugs into stock engine harness and off you go.
Omni-power is the same too.
Old May 23, 2010 | 02:48 PM
ChefJ's Avatar
aem 3.5 bar the 1052 has settings for it and is obviously compatible
Old May 23, 2010 | 06:04 PM
jb34304's Avatar
does it just go into the factory location? Do I need to drill anywhere and weld a bung? I know I do for the UEGO sensor but I am also unsure on how to install it. Any suggestions would be helpful.
Old May 23, 2010 | 11:30 PM
godmachine's Avatar
AEM goes in stock location using tuner toyz adapter. Get the SOS 3bar map it works just fine with the 1052
Old May 24, 2010 | 01:16 PM
jb34304's Avatar
With the hodadata sensor, do I choose the honda/accura all from the wizzard?
Old May 24, 2010 | 01:26 PM
Irishflame27's Avatar
no, that is for stock OEM maps
specialist
Apr 17, 2012 09:24 AM
ScienceofSpeed
Jan 24, 2011 01:17 PM
jb34304
May 24, 2010 02:26 PM
EriS2k
Apr 22, 2008 05:43 PM
waytooslow
Apr 24, 2006 08:04 PM
