Bigger battery for forced induction?
Old Mar 5, 2018 | 12:46 PM
Mijae007's Avatar
Originally Posted by engifineer
Ah, makes sense. I thought it had to be mostly for room on the FI side. I guess I can see the engine bay cleanup .... but I look at the S as a function >>>>> form car.... so dressing the engine bay up didnt even come to mind :P
Definitely. I actually like the look of everything in its factory location simply with a clean and sparkly engine bay. Not really into tucking and hiding various parts.
Old Mar 5, 2018 | 01:09 PM
Charper732's Avatar
Originally Posted by LostMarine
Although I agree with you, that wasnt my case. the wire itself went bad somehow, looked 100%. Thats what took weeks to diagnose. when i say instantly grounded new wire, all power came back. tried old wire, dead as nuts. something inside it went to shit or disconnected under the casing. would never be able to tell visuallly
Next time you suspect a wire being bad just turn your meter to Ohms and put a lead at each end. If the resistance is any kind of high, the wire is bad
Old Mar 6, 2018 | 05:53 AM
nguyen365's Avatar
Originally Posted by flexer
Its not the battery its the relocation that is killing you. When you relocate a battery to the trunk most use too small of wire running to the front and the wire quality is usually crap which only exaggerates the problem now that you have added a ton of length. Next thing is as others have stated above that grounding to several points in the trunk is a must.
I think that's what I'll do. I currently have 2 8 gauge wires on possitive and 2 8 gauge negative. The 0 gauge wires are expensive lol. I'll just switch it up and use 4 8 gauge wires on positive (cuz it's already there installed). and buy a short 0 gauge for the negative and ground it to the trunk sanding down the contact point of course.
Old Mar 6, 2018 | 08:58 AM
Mijae007's Avatar
Anyone recommendations on battery brand? Guy at autozone told me optima got bought outnand id be lucky if it lasts one year...
Old Mar 7, 2018 | 01:49 AM
RolanTHUNDER's Avatar
Is the battery code/size supposed to be 634?
Old Mar 8, 2018 | 03:58 AM
jordannn93's Avatar
I have a 24f size battery in my trunk . 700 cca
grounded to rear strut bar
Old Mar 8, 2018 | 06:02 AM
Mijae007's Avatar
i think its 51?
Old Mar 8, 2018 | 06:26 AM
nguyen365's Avatar
Ohh thanks for that shot. Is that under the spare tire? 2 gauge negative wire from Walmart is $11 .lol
Old Mar 8, 2018 | 12:33 PM
engifineer's Avatar
While I normally try not to look at autozone, let alone go in one, I will say he was right. Not sure about being purchased by who, but the past two I had were crap. Both lasted a couple of years. For reference, the stock battery one of them replaced lasted 10 years of MN winters before it died. I have moved to other brands. Will never waste money on another Optima. I think they used to be great, but now are no better than a cheapo brand, but cost way more. I have Bosch in two vehicles now ... but have not had them long enough to say if they are better.
Old Mar 8, 2018 | 10:05 PM
i think its 51?
Thanks. Um 51? I'm not familiar with that numbering. I'll have to look it up because locally we get 3 digit battery codes far as I know lol
