Bigger battery for forced induction?
Old Mar 12, 2018 | 10:42 PM
  #31
RolanTHUNDER's Avatar
Originally Posted by flanders
A small amount of dielectric grease on those ground connections is recommended.
The battery shop I got the new lead from sprayed terminal protector on the battery terminal itself and on the chassis bolt. Should be good?
Old Mar 12, 2018 | 10:43 PM
  #32
Originally Posted by LostMarine
told ya
Arigato
Old Mar 12, 2018 | 10:47 PM
  #33
flanders's Avatar
Sounds good
Old Mar 12, 2018 | 11:52 PM
  #34
Sounds good
How's the Swedish metal scene nowadays? Any other good bands apart from In Flames, Katatonia and Avatar?
Old Mar 13, 2018 | 08:38 AM
  #35
engifineer's Avatar
Originally Posted by Mijae007
I just picked up a bosch agm battery with 450cca. Hopefully ita good. Price was pretty good at $160 with 3yr warranty
that is what I replaced the Craptimas in my other cars with. I got both for under $120 each though.
Old Mar 14, 2018 | 08:43 AM
  #36
nguyen365's Avatar
Originally Posted by RolanTHUNDER
I just replaced my negative terminal with a brand new thicker gauge wire on Saturday. I also replaced the terminal connectors (from the battery to the chassis) and that solved the problem of intermittent power cuts. Those cuts would cause the ECU to reset and then have to relearn which would cause the car to switch off sometimes when coming to a stop and during idle. You know what I mean. My driver's window would lose its auto setting when those cuts would occur as well. Now she's all good
When I looked closely at the underside of the old wire I was shocked to see how much corrosion ate away at it! The connector itself was in poor condition too. The bicarb and hot water cleaning I did two months ago didn't really help that much. No wonder there was an earth leak...
.I did just this today. 1 24f battery with 750cca and 2 gauge negative grounded to the rear strut var.
Old Mar 14, 2018 | 08:45 AM
  #37
nguyen365's Avatar
Let us know how that holds out when u're on e85 bro
Old Mar 14, 2018 | 03:10 PM
  #38
Mijae007's Avatar
im already on e85. Setting up a flex tune so i can run 91 too. I started up the car a few times this week with no issues. It should be fine, we'll see. Ive used the yellow top optima my last two batteries each lasting around 3-4years.
i like the drycell agm batteries since they cant leak. And especially with the battery being in the interior i like the safety of that. But not that any of my previous batteries leaked...
Old Mar 15, 2018 | 04:13 PM
  #39
pde27's Avatar
Been having same issue with odyssey battery(hks supercharger) for awhile. Just got a braille 2015 and it’s on pare with what the car needs. I use stock location so had to use a die to make the threads a little lower on the hold down. Happy so far, yet we will see. Btw, summit does it for $199.99 with free shipping.
Old Mar 16, 2018 | 05:28 AM
  #40
nguyen365's Avatar
Not bad online braile g20 was $459 ouch..
