Boost & AFR gauges for Vortech
Old Jan 24, 2005 | 02:38 AM
kstokell's Avatar
Default Boost & AFR gauges for Vortech
What boost and AFR guages do you guys recommend for use with the Vortech SC?
Old Jan 24, 2005 | 04:05 AM
Salaska's Avatar
I have a comptech sc, but this makes no different which gauges you choose.
At the moment i use a Defi BF-Series Boost and Oil Temp Gauge. For the AFR i use a PLX M-300 Wideband and it works great, you also don't need to make a new plug-hole on your header as the PLX can emulate a narrow signal for the stock ecu.
Old Jan 24, 2005 | 07:59 AM
xviper's Avatar
Moving to F.I. forum.
Old Jan 25, 2005 | 05:22 AM
Sideways's Avatar
I like the Apexi boost gauge. It has a memory function to check your peak boost and a warning function you can set anywhere you want. I coupled that with the Apexi EGT. It also has the memory and warning functions.
Old Jan 25, 2005 | 07:09 AM
kstokell's Avatar
My main issue is do not want to have gauges all over the car. What I'm really looking for is a singal digital readout that can be switched between a few sensors. I would like to be able to monitor boost, AFR, and Oil temp.
Does such a set up exist?
Old Jan 25, 2005 | 12:14 PM
honda9krpm's Avatar
kstokell, use the search button for "blitz gauge' posted by "fireball"
it's very neat and useful
Old Jan 25, 2005 | 12:16 PM
Salaska's Avatar
You could use a Greddy E-01 Display + Signal Harness. With this setup you can splice 3 Sensors to the harness like Wideband, Boost, Oil Temp and watch them together on a small LCD-Monitor.
But you need the sensors and also a wideband controller for it.
s2guru
May 2, 2009 02:11 PM
Nhan
Jun 14, 2006 07:15 PM
jahnke
Jan 29, 2005 04:37 PM
Jip69
Dec 14, 2003 01:36 AM
scs2000
Nov 12, 2002 03:10 AM
