Boost & AFR gauges for Vortech
I have a comptech sc, but this makes no different which gauges you choose.
At the moment i use a Defi BF-Series Boost and Oil Temp Gauge. For the AFR i use a PLX M-300 Wideband and it works great, you also don't need to make a new plug-hole on your header as the PLX can emulate a narrow signal for the stock ecu.
I like the Apexi boost gauge. It has a memory function to check your peak boost and a warning function you can set anywhere you want. I coupled that with the Apexi EGT. It also has the memory and warning functions.
My main issue is do not want to have gauges all over the car. What I'm really looking for is a singal digital readout that can be switched between a few sensors. I would like to be able to monitor boost, AFR, and Oil temp.
Does such a set up exist?
You could use a Greddy E-01 Display + Signal Harness. With this setup you can splice 3 Sensors to the harness like Wideband, Boost, Oil Temp and watch them together on a small LCD-Monitor.
But you need the sensors and also a wideband controller for it.
Nhan
Jun 14, 2006 07:15 PM
scs2000
Nov 12, 2002 03:10 AM
