Boost Creep?
Old Apr 11, 2006 | 07:35 AM
  #21
Tinker219's Avatar
Are you using a boost control selenoid? If youre running off of just the wastegate spring, this may be some of the issue, as the boost control selenoid allows complete control, and has shown to eliminate boost creep in some of my previous setups.
You might want to pull the wastegate off, pull the WG top off and make sure the diaphram is not pinched. I have had wastegates directly from TiAL that had pinched diaphrams. Check this out, as it sounds like it could be a culprit.
Old Apr 11, 2006 | 08:09 AM
  #22
ex-eclipse's Avatar
Thanks for the advice Spoolin I will keep it mind.
Cody, you're alive! I'll give you a call.
1SlowSi
May 1, 2012 03:53 PM
1SlowSi
Apr 24, 2012 05:58 AM
Peter@ISP
Jul 23, 2009 07:43 AM
shauminside
Aug 8, 2004 06:45 AM
