Boost level on stock motor E85 or other fuel
Old Sep 19, 2011 | 07:08 PM
ZwnC's Avatar
Boost isn't really the limiting factor here - its heat.
Compressors are inefficient, and generate heat while they compress your charge air. Different impellers have different efficiency characteristics at different flow rates and pressure levels.
If the combination of heat from the turbo, piston compression, and timing advance is too great, you'll get detonation.
Good intercooling helps reduce IATs. Higher Octane fuel will tolerate higher temp/pressure.
"How much boost can I run" is a simple question about a complex issue.
Old Sep 19, 2011 | 08:08 PM
EternalLx's Avatar
Theres heat but theres also strength of the components (Piston, Rods, etc)
Example: a stock K20 can make 500+ but the rods cant take the power for very long.
Old Sep 20, 2011 | 05:48 AM
sohc_mshue's Avatar
Originally Posted by soulicious
Does cylinder pressure matter?
Bingo! This is a big part of it.
Old Sep 20, 2011 | 05:52 AM
penguinsintuxedos!?'s Avatar
I agree that this is another broad question with many specific answers that don't fit. It does very much depend on more specific information, although I also agree that you will be fine at 22psi. I run 32psi on the street 10k miles a year, it won't last forever, but no problems yet!
Old Sep 26, 2011 | 05:37 AM
S2k6262's Avatar
Fred a Horse Power Connection in FL has a bone stock unopened motor, just tuned on 20 psi and made 625, and now the car is on 26psi
Old Sep 26, 2011 | 02:28 PM
BrockB's Avatar
lets go more in depth with this... anyone?
Old Sep 28, 2011 | 09:54 AM
GoOn3's Avatar
I'm with Brock on this one.... Can we get some more explanation for cylinder pressures and what is considered safe and best for endurance(longer life of motor) and how can you figure out what the max efficiency of a turbo/manifold before it is piping hot or hotter air than is optimal? Notice i say optimal as i realize its possible with tuning and higher octane to quail hotter AIT's and the subsequent detonation. But what is "optimal" or maybe better said as perfect in a perfect world?
Thanks guys! Have at It!
@Mark-Realstreet.....Concerning the MoTec SKM... Is there something of equivalence that is for the AEM?
Thanks
Old Sep 29, 2011 | 01:46 PM
GoOn3's Avatar
Up
crb5885
Aug 14, 2012 07:48 AM
08s2000CRbackinblack
Dec 30, 2009 05:46 PM
Headchef
Aug 31, 2007 11:43 AM
johnnyboy
Aug 23, 2007 08:46 PM
Scorpion
Nov 15, 2005 04:44 AM
