BRP "Hotside" Supercharger
Old Feb 6, 2006 | 07:43 AM
  #181
Birdie's Avatar
Was the dyno on stock headers and exhaust? also what was the psi level set at?
Old Feb 6, 2006 | 07:44 AM
  #182
Brant @ BRP's Avatar
Stock Header, Stock Exhaust and 6 PSI.
Brant
Old Feb 6, 2006 | 07:51 AM
  #183
Originally Posted by WestSideBilly,Feb 5 2006, 09:01 PM
Brant/Joe: Any thoughts on the dip before the cam switches at 6000 RPM?
I think we just need to lower the VTEC engagement point. The hardware to do it is already built into the ELF, we just have a little code to write.
Brant
Old Feb 6, 2006 | 07:53 AM
  #184
Birdie's Avatar
Brant
hmm not bad for 6psi.
Old Feb 6, 2006 | 08:32 AM
  #185
S2K00's Avatar
Yea... Not bad at all for 6 psi! How hard is it going to be to change the psi? Thanks
Old Feb 6, 2006 | 08:58 AM
  #186
DeViL's Avatar
Not necessarily directed at the guys at BRP but I might have a situation.
I have a 12" sub w/box in the wheel well of the s2k where the battery (I'm assuming) will be moved for the hotside SC. It was addressed in the BRP forums that the batteries need to be "contained" with a cover so I pretty much can't have one free floating in my trunk. I know this should be a simple fix if I can find a place that would make a housing for the battery that I could keep on the side of the trunk. Does anyone know where I could find something like that or have an alternate solution to my predicament?
Thanks
No more poems for now...
Old Feb 6, 2006 | 09:50 AM
  #187
Habitforming's Avatar
Here's my experiences with this situation:
1) As the battery isn't in the passenger compartment (assuming it's still in the trunk, of course), most racing bodies won't require a battery box
2) Many racing bodies will permit no battery box if the battery in the pass compartment is of a certain type (sealed, maintenance free, gel cell, etc are common names of this battery type). Regardless of what you're calling it, the important part is that the battery can take damage to the case and not spill its contents.
3) Battery boxes are widely available from your typical racing supply companies. You can use any type of automotive battery inside of one of these housings, and be within the rules for most anything you might participate in. Below is a Jeg's search I just performed, I hope this doesn't break any forum rules in the case that they aren't a paying sponsor!!! Jeg's Search
*** Standard disclaimer: If you plan to participate in any sanctioned racing events, please check their specific rules in regards to this issue. These comments are based on my own experience and I'm sure are not universally applicable.
Old Feb 6, 2006 | 10:01 AM
  #188
DeViL's Avatar
Thanks. That more than answers my question.
Old Feb 6, 2006 | 10:12 AM
  #189
trivium's Avatar
Banned
Originally Posted by jakub2000,Feb 6 2006, 03:40 AM
2.trivium is the troll to be ignored.
I came across 4 stupid comments of yours in 5 threads I opened today, congrats!
Did you have a bad day or are you just trying to impress us by being oversmart?
You don't even own an S, so why don't you just calm down and let us be.
Dont you have anything better to do like beat Ferrari's and Carrera GT's in street races?
Or post pictures of your wife ?
I posted an incorrect fact and I was corrected. I admitted it and wasnt trolling. Whats your problem?
Old Feb 6, 2006 | 10:13 AM
  #190
James @ BRP's Avatar
The Miata has the battery sitting off to one side of the trunk. It's not really "boxed" in. The early Miatas ('89-'97) had them simply held down securely with a mount and covered with a flimsy piece of interior carpet like trim. The later Miatas ('99-'05) actually have them down in a well of sorts increasing useable trunk space. Again, off to one side and securely mounted to the floor. The '99+ cars though have a particle board covering over that well. Don't see why you couldn't do something similar. I'd still fabricate some sort of panel to protect the battery from objects in the trunk rolling around.
