BRP "Hotside" Supercharger
Old Feb 7, 2006 | 05:38 PM
  #241
slimjim8201's Avatar
[QUOTE=Habitforming,Feb 7 2006, 08:53 PM]You VT guys sure aren't edumacated too well
Old Feb 7, 2006 | 05:39 PM
  #242
Originally Posted by shuneycutt,Feb 7 2006, 08:58 PM
The roots type supercharger moves a constant amount of air which is higher than the engine's (because it is geared higher than the engine). It moves more air the higher the RPM but the engine needs more air the higher RPM, so the engine still gets the same (higher) concentration of air from the supercharger throughout the RPM range. Hopes this makes sense. Again, thanks in advance.
Spot on!
Old Feb 7, 2006 | 06:17 PM
  #243
S2K00's Avatar
Originally Posted by trivium,Feb 7 2006, 05:09 PM
The tune was done by the best but the construction of the kit he was using was flawed. He has modified the design to get a more linear powerband since his last dyno.
BTW, would it be wrong to say that $1100 for an extra 30whp is too much?
I thought the same exact thing when I first looked at it... but when you actually think about it, it's a good deal!! A header cost around $1000 and you get anywhere from 6-10 hp, exhaust is around $1000 and you get anywhere from 4-8 hp, etc... So it's actually not that bad of a deal!!
Old Feb 7, 2006 | 07:13 PM
  #244
Bill @ BRP's Avatar
Originally Posted by slimjim8201,Feb 7 2006, 05:04 PM
A centrifugal compressor (centrifugal supercharger or compressor stage of a turbocharger) provides boost (and additional flow-rate) exponentially proportional to the speed it is spinning. The faster it spins, the more boost. Note that it is NOT a linear relationship.
A positive displacement supercharger (Roots, Eaton, or lobe type) is less of a compressor than it is an air pump. It does not compress the air, it merely moves it from one location to another. All of the compression takes place after the air exits the supercharger. A centrifugal compressor increases the air pressure inside it's housing, in addition to any compression that will occur downstream due to lots of air being rammed into a small space.
Let's speak in ideal circumstances. The roots-type blower has the ability to move X amount of air at Y RPM in a linear fashion. It will move twice as much air (flow-rate) with twice the rotational speed. Coincidentally, an engine also needs air in a linear fashion. If paired correctly, the roots-type supercharger will provide exactly Z times the amount of air an engine would normally need at all RPM. This corresponds to constant boost throughout the rev range.
Of course, ideal circumstances are just that. No matter what someone selling a roots-type supercharger will tell you, they do lose efficiency at higher rotational velocities. This is why you see the boost drop off at higher RPM in almost all Roots applications. However, there have been many advancements in their design and they are vastly superior to the chargers of old.
Mostly correct, but the last part about the "roots" losing boost at high rpm has not been my experience in helping develop BRP supercharger kits. I have done a lot of boost datalogging on both the Miatas and now the S2000 setups and they all start off at lower boost at low rpm and make more boost at high rpm. However, do not confuse higher boost necessarily meaning a higher boost in power. It is true that with a positive displacement supercharger a fairly constant air volume is moved per rev, however this is not the only thing that determines the boost that is measured in the manifold. The more restrictive the engine is downstream, the higher the boost that is seen in the manifold. The volumetric efficiency of the MP series of superchargers is improved from the last generation of the M series.... particularly at higher supercharger rpm and boost levels. The volumetric efficiency actually increases with rpm. For example, at 10psi the MP62 has about an 82% VE at 10000rpm (supercharger). By 16000rpm at 10psi the MP62 has a 95% VE. At the same time, the engine's VE generally decreases with rpm. This means that with a given pulley ratio for the supercharger, the ratio of air trying to exit the supercharger vs. the amount that the engine can consume shifts. This ratio is part of what determines the pressure ratio in the intake manifold and thus the gauge pressure in the intake manifold. Having more boost is actually not a good thing as it really indicates restriction to flow. Of course you can't always have 0psi and huge amounts of flow , but with a given supercharger pulley ratio seeing less boost at the intake manifold after doing things like headwork or exhaust changes generally reflects itself in higher output on the dyno.
On the dyno measuring boost I thought it was pretty interesting how the boost dropped about 1psi when the engine hit VTEC and torque made a nice increase. Basically the boost started at 5psi at low rpm rose to about 6psi right before VTEC, dropped to 5psi after VTEC and then climbed back up to 6psi at the rev limiter. As can be seen on the dyno graph, the torque remained flat and didn't drop off much at high rpm. I think this is also a testament to the efficient S2000 engine. In contrast, on our Miatas the boost generally rises about 3psi from low rpm to redline. The Miata engine of course doesn't breath as well as the S2000 engine at high rpm .
Bill
Old Feb 7, 2006 | 08:15 PM
  #245
PilotKD's Avatar
I remember when I installed the JR kit on my '99 Miata a few years back, I was seeing 5-6psi. I then installed a JR header a few months later and was only seeing 4.5psi or so, but I actually gained 5-10whp.
Old Feb 8, 2006 | 03:52 PM
  #246
Originally Posted by Bill @ BRP,Feb 7 2006, 11:13 PM
Mostly correct, but the last part about the "roots" losing boost at high rpm has not been my experience in helping develop BRP supercharger kits. I have done a lot of boost datalogging on both ...........
Awesome
Old Feb 8, 2006 | 04:20 PM
  #247
S2K00's Avatar
Ok.. so one thing I'm not to clear on is do you have to relocate the battery to the trunk?? And will this kit include everything needed to do so...???
Old Feb 8, 2006 | 04:25 PM
  #248
PilotKD's Avatar
Originally Posted by S2K00,Feb 8 2006, 07:20 PM
Ok.. so one thing I'm not to clear on is does this kit come with the battery relocation kit??
I'm sure it will come with everything needed to turn the key and go. As much as I'm psyched about this kit, I dread having to relocate the battery to the trunk and replacing A/C lines. Doesn't sound like this is going to be a quick install, although I guess if that's what has to be done, it has to be done.
Old Feb 8, 2006 | 04:28 PM
  #249
S2K00's Avatar
^ Yea... I feel ya on that but sometimes there are sacrifices that just have to be made.
Old Feb 10, 2006 | 10:21 AM
  #250
vader1's Avatar
Originally Posted by Birdie,Feb 7 2006, 06:16 PM
wow 12.7 in the 1/4th not to shabby..
and 0-60 in 4.5
Just the kind of kit I have been waiting for and I WILL purchase one.
Just first need to pay for the engagement ring, the wedding and honeymoon.
Looks like spring 2007 for me. I can't wait.
