BRP/SOT Hotside SC Install
Originally Posted by WLAURENT,Mar 4 2007, 07:58 PM
The SOT kit uses a piggyback called an ELF (emissions legal fueling). The ELF uses boost (on board map sensor) and the injector cycle that is being sent from the ECU to determine how much longer the injector needs to be held open. You adjust the tip in (where added injector duration is required), the amount of additional duration per pound of boost, and the maximum duration. My early impression is that it works and leaves the car in a very drivable condition - but it is not perfect. I would prefer that you could map on boost, rpm, etc.. Idealy it would be nice to have a piggyback that allowed you to set a target AF ration (from a wideband) and then have it manage from there.
Originally Posted by chairmnofthboard,Mar 4 2007, 11:01 PM
but the vortec makes more power?
I'm just wondering what are the pro's to this blower vs vortec?
It doesn't move much air until the high rpm range. It is more for showing off high peak dyno numbers than real world performance.
The Eaton moves air over the entire rpm range - you have full torque from very low rpm ...
Originally Posted by duff0000,Mar 4 2007, 10:31 PM
Wow, thats nice, Any kind of whine from the S/C? or is it totally silent stealth mode?
Originally Posted by mike2016,Mar 5 2007, 12:01 AM
think about moving the S/C to the intake side instead.
Originally Posted by mx5,Mar 5 2007, 12:23 AM
Vortec is a centrifugal
I am very interested in this Supercharger kit.
Originally Posted by WLAURENT,Mar 4 2007, 10:58 PM
Certainly..
Anyone interested in the bracket to mount the fuse box? There were a couple of PM's from people asking about it - but I did not recognize them as frequent members here.
I will ask them about it this week.
I am turbo with a log style manifold and i want to move the heater valve in that orentation. if i can move the fuse box that way also, it would be great! thanks for asking.
