BRP/SOT Hotside SC Install
Originally Posted by mx5,Mar 5 2007, 12:23 AM
Vortec is a centrifugal
It doesn't move much air until the high rpm range. It is more for showing off high peak dyno numbers than real world performance.
The Eaton moves air over the entire rpm range - you have full torque from very low rpm ...
The vortech CAN deliver mid range power, just has to be set up that way.
I really don't understand why people try to get lowend power out of an s2000. If that's the case go turbo.
Originally Posted by chairmnofthboard,Mar 5 2007, 09:12 AM
I like the power being linier. I like the power being delivered the same way the engine produces power, Considering that when you are tracking the S you will be at 6000-9000 rpms the whole time.
. VT and CT are great, but you don't feel the boost until its up top. Also, I don't know to many DD turbos that don't have problems.
^ i feel boost all over the powerband. i get 4psi at 4000-4500rpms. but about the SC can it be installed without the oem header setup because it looks like you have to use the heatshelid, or have an aftermarket header thats has the oem brakets on them.
Originally Posted by BulldogS2,Mar 5 2007, 09:22 AM
Personally, i would prefer to have the lowend for daily driving. If i spend 5-6k on a mod, i would like to feel it
. VT and CT are great, but you don't feel the boost until its up top. Also, I don't know to many DD turbos that don't have problems.You don't feel boost till the top, but your car also doesn't make power until the top.
I've turbo cars, and they can be reliable. Just have to be done right.
Originally Posted by duff0000,Mar 4 2007, 10:31 PM
Wow, thats nice, Any kind of whine from the S/C? or is it totally silent stealth mode?
Originally Posted by Guedo512,Mar 5 2007, 08:08 AM
interesting.
Can this work with an after market header and no heat sheild?
I believe the Mugen header retains the OEM heatshield - so it would mount perfectly.
Originally Posted by blxmjx,Mar 5 2007, 09:31 AM
any idea whether the manufacturer will to attempt to obtain CARB cert #'s for this kit? That would be a huge selling point. I personally wouldn't buy a FI kit w/out CARB cert's.
The centrifugal blowers are the ones that alter the stock linear power buildup ...
About the tracking part - not on every track and out of every corner you can be in the 6000-9000 rpm range. And shifting takes time so sometimes it's better for the clock to stay in gear and then the extra power helps
[QUOTE=mike2016,Mar 5 2007, 12:01 AM] not here to talk sh!t but I have to point out some potential issues with a kit like this....
1. the amount of factory parts need to be removed/modified. not very "bolt on" / "oem" install.
