BRP/SOT Hotside SC Install
Originally Posted by Enthralled,Aug 11 2008, 11:52 PM
it can't? why?
Just need a DBW car that is willing to let SOT have there car for a couple of weeks so they can integrate the DBW components into the 74mm Billet Throttle body.
Since there is no one local to me that has spoken up with a DBW car I do not have a DBW car to build a basemap with.
The Fueling/Timing should be the close/same but just wanted to make sure that the DBW tunning is incorporated correctly into the tunning aspect of things.
Remember on the AP2 it was necessary to tune a TPS voltage ramp smiler to what greddy does on their AP2 turbo setup.
The Voltage ramp will still apply on the DBW AP2 unless some one goes with a full standalone or Kpro.
So even once SOT gets a DBW test car the kit will still most likely come only as a tuner kit version for the DBW cars or full kit with just timing and fueling maps but everything else left open for your tuner. . That is unless someone is willing to come to Huntsville so I can build a full base map on the dyno ( Dyno Dynamics)
Originally Posted by MugenRioS2k,Aug 11 2008, 10:09 PM
it can
you can also use the HKS F con, they work for the DBW cars, but it's a bit $$$$.
btw If I had to start over, this is the kit I'd get.
Originally Posted by MugenRioS2k,Aug 11 2008, 11:42 PM
Yes
There is one going out to a owner in Ft Lauderdale.
Stock except the kit and a AEM EMS
its for the most part stock. has berk header and testpipe, but otherwise, will be just the blower and aem ems.
rc 650 injectors
walbro fuel pump that comes with kit
still have stock clutch for now. will report back as progress is made
it can
How close are you to Atlanta.
There is a AP1 Beta in ATL. (AP1 on AEM EMS)
He does not frequent the forums/s2k meets a lot so I would need to contact him directly if you want to get a ride.
For anyone that wants to come by and take a look first hand or possible get a ride if we can find the right venue.
I will be at the NOPI replacement show in September 20,21.
http://www.motorsportnationals.com/
If the NOPI replacement show does not happen I would be willing to take a trip around the same weekend to ATL if there are ppl wanting to take a look.
I will be in Macon around that time anyways to celebrate my B.Day (Sep 25)
