BRP/SOT Hotside SC Install
Old Aug 1, 2008 | 08:52 AM
  #691
camuman's Avatar
i have a utune kit coming my way in the next few weeks .
next weekend gonna install the new 650 rc injectors, aeromotive fpr, and walbro pump. then tune it part throttle and idle. then install the blower the following weekend. tune it again part throttle in boost, then head to local dyno for final wot tune
i will start new thread as i progress on install
Old Aug 1, 2008 | 07:35 PM
  #692
GRUNTS2K's Avatar
Old Aug 2, 2008 | 12:57 AM
  #693
OnlyHonda4me's Avatar
Make sure you put a link to the new thread here!
Old Aug 10, 2008 | 07:01 PM
  #694
derek14's Avatar
we sure need an update
Old Aug 10, 2008 | 07:23 PM
  #695
MugenRioS2k's Avatar
Everything is still running great ( do need some new tires ) other then a small vacuum leak on my PVC catch can ( Air inline water accumulator from Lowes). Cause a very brief lean spot when getting back on the throttle at light throttle positions. Even with the vacuum leak the A/Fs stay good when in boost.
Crap just realized I never posted the dynos showing the gains in the midrange by dropping vtec down to 4k. TQ curve is flat now absolutely no vtec surge just lots of area under the curve.
psi in the low to mid range did drop down to 5.5 (as expected with the vtec lobs down low) with Tq increasing. Any time power (TQ) goes up and boost goes down you are putting your motor in a much happier place.
I am looking into a SNOW water injection system to see how much power can be gained due to water injection; increased spark timing that can be run with water injection. ( starting with snow since it is cheep eventually will steep up to a aquamist setup with full 3D mapping ability which can be controlled by the ULT if you really know how to use the ULT to its full extent.
I am hoping I can push the power up to 350Whp and about 225-230WTQ with the water injection system and increased timing.
Even as it stands now since IATs are so low in boost I am only pulling about .5 deg at 5 psi and 1 to 1.5 deg at 6.5 psi depending on rpm.
Old Aug 11, 2008 | 06:31 AM
  #696
vader1's Avatar
Mark,
Is there any plan to work the Vtec drop into the included basemap in the future?
Old Aug 11, 2008 | 06:54 AM
  #697
Yep that
Old Aug 11, 2008 | 07:02 AM
  #698
vader1's Avatar
Good news, thanks.
Old Aug 11, 2008 | 03:50 PM
  #699
derek14's Avatar
Are there any plans to install this kit on an AP2 that is COMPLETELY stock?
I wonder what the numbers will look like
Old Aug 11, 2008 | 08:42 PM
  #700
Yes
There is one going out to a owner in Ft Lauderdale.
Stock except the kit and a AEM EMS
