Calling out the people with nitrous.....
Old Dec 7, 2005 | 01:14 PM
CIVICTOS2000's Avatar
Default Calling out the people with nitrous.....
Which one is the Gas line you have to cut to get the gas to the Gas solenoid? I'm trying to buy one or get one from a junk yard in case I wanted to got back I can put a new one......How do you call that line? Thanks
D.
Got part Number ? even better......
Old Dec 7, 2005 | 03:52 PM
Slows2k's Avatar
Moving to FI
Old Dec 7, 2005 | 05:21 PM
blues2k3's Avatar
well its not recomended to cut the fuel line for your nitrous setup. Usually putting a tee with clamps will result in fuel leak. Try tapping the fuel rail itself with an 1/8 inch tap then use an 1/8 inch to -3AN fitting which should connect to your stainless steel braided line going to the fuel solenoid...Use some telfon paste on the 1/8 thread but not on the AN thread. Good Luck.
Old Dec 8, 2005 | 04:49 AM
^^^^^Thanks.....Does anybody have a pic on this? Thanks...
D.
Old Dec 8, 2005 | 03:15 PM
JDMKID35's Avatar
Banned
Old Dec 9, 2005 | 11:33 PM
S2oooNvegas's Avatar
if your going to tap into the stock supply, please run a larger fuel pump, or setup a seperate fuel system for the nitrous. i wish people would stop using fuel from the rail, it already has its job cut out for it. its not ready to supply enough fuel for another 75 hp+.
later dave
TonysMI4
Aug 28, 2011 11:21 AM
Blucky87
Mar 22, 2011 06:25 AM
siadam
Apr 25, 2009 06:53 PM
mikdys
Car Talk - Non S2000
Jun 12, 2008 11:47 AM
dml256
Apr 19, 2005 06:22 AM
