CEL after Vortec Install
Old Jun 17, 2006 | 08:18 PM
icemans2k02's Avatar
Default CEL after Vortec Install
Ok i installed my vortec supercharger and all seemed well for the first day of driving. Next day i cranked her up and she throws a CEL. Reset ECU and again all is well no problems with car...boost is good.. then next day start her up and throws a CEL. I have yet to check the code and will be tommorrow. Just wanted to know if anyone had this problem and knew what it was. I am running a test pipe with t1r exhaust ( with the O2 fix) and vortech supercharger kit. Again i can drive it for a day or for the third startup before she throws a CEL. Any input would help I am a little frustrated
Old Jun 17, 2006 | 08:21 PM
Slows2k's Avatar
Moving to FI
You need the actual DTC # to begin to figure out what is wrong with the car.
Old Jun 17, 2006 | 08:27 PM
xviper's Avatar
Stop clearing the code until you know what it is and fix it.
Old Jun 17, 2006 | 08:35 PM
SilverKnight's Avatar
probably vaccum, code comes onw hen engine is cold. Took 3 days for the mechanics to figure otu what hose it was.........you have to try to fix it then test it out severla hours later, time consuming. that T1R is making you run lean if you still on stokc injectors or not tuned, T1R leaned by 1 point at least in the high RPMs...
Old Jun 18, 2006 | 04:07 PM
Enthralled's Avatar
I had the same problem when i first installed my vortech....My vac lines were crossed...
No one can really help you unless you get the code pulled...
Autozone
Peace
David
Old Jun 18, 2006 | 05:37 PM
thanks slows2k and boosted it was a kinked vac line just had to look for it good and there it was!!
Old Jun 18, 2006 | 05:38 PM
ohh sorry and thanks silver knight to
Squirtle
Feb 6, 2011 01:30 AM
JDMQuip
Aug 11, 2008 07:09 PM
brilliant
Apr 11, 2008 03:57 AM
IwantaS2000
Sep 10, 2006 09:33 AM
jin6
Sep 2, 2005 10:28 PM
