CNC Speedshop built engine
Originally Posted by Habitforming' timestamp='1446214652' post='23790299
[quote name='Pinky' timestamp='1446213100' post='23790284']
[quote name='AFs2k' timestamp='1446000679' post='23787938']
Well hell, I was saving pennies for their diff kit... Guess that's not gonna happen now.
Edit - Oh I see, you live nearby. Local pride maybe?
[/quote]
Every business will have one upset customer. Be it justified or not. No matter what they will not be happy. I do know Jason and yes he is local. Not a "friend" other than a fellow S2000 owner like all of you. Visited his shop and did a tune on my car. Do I trust him less now.....a little but it would only to be sure that I double check delivered product.
Honestly if I were to ever get another engine.....it would be OEM or if I re-built I would be part of the re-build process and have that person install/tune the car. Never to order and install....and surely not order international the install.
Just my opinion and my view.
Agree. This thread needs to just die!
Chive on.
[/quote]
Why does it need to die? Because it isn't your problem? If you don't like it, GTFO. OP's problem is not resolved.
I agree,why should this thread die?it's easy to move on and read the next topic,forgetting about the one you've just read.
I think it should be refreshed when ever the Op feels like it......with justifiable reason.
With my own thread I think that I can justify keeping it going for as long as it took me to earn the money that Kings Performance has kindly squandered for me.So I'm looking at another 4 years at least.
On the odd ocasion I get a knob head popping up and asking why I keep insisting on keeping the onslaught going.....my answer, when close on $20.000 has been spent and basically I have nothing to show for it,why should I allow them to ride the storm then just let it blow over.
That reminds me.....
had a bad experience with cnc, no where near as bad. I pm'd them about a 2.4L na setup. They told me a 2.4 crank with stock ap1 pistons would be good for a pump gas street motor with occasional traking. They told me it would put me around a 14.1 compression, and that it would be able to rev well past 9k.
I canceled my order.
kept my mouth shut because, well they were vets. but if i was to of assembled that motor it wouldn't make it past 5K with my driving.
Ah... You don't want a magic motor that has piston speeds a good bit higher than an F1 engine (even with an 8,600 RPM limiter), all while running pump gas on 14:1 compression?
i say keep em open so that new people don't get scammed i have motor anxiety with no good build options and no new short blocks available from Honda. I am about to drop my pan and do some checking possibly replacing rod bearings and installing a moroso baffle i welded into a spare pan
Give Bernard at Jjautowerks a shout,he was selling a brand new built short block,even if he sold it he will sort you out.
