compressor surge?
Old Oct 24, 2010 | 05:45 AM
teamvalorracing's Avatar
Originally Posted by mcs2k21,Oct 23 2010, 11:47 PM
The shaft was way loose, I'm pretty sure something broke, can a surge cause the shaft to break?? If the bov didn't function wat problems occur??
see. things were left out. next your gonna tell us there was a long crack down the back of the gear housing and a dodgeball got sucked into there.
if the shaft was loose and flailing around, then the shaft broke, bearing, or gear pin broke. if your bov had a leaking gasket and the vac was still hooked up, it was blowing off plenty. your issue had to do with something else dude. idc what Vortech said.
Old Oct 24, 2010 | 12:39 PM
mcs2k21's Avatar
U didn't answer my question, if the bov fails, wat will happen?, it has to b there for a reason
Old Oct 24, 2010 | 01:44 PM
Sideways's Avatar
That compressed air against the closed throttle body will cause the throttle shaft to wear and break without the bov.
Old Oct 24, 2010 | 02:20 PM
its there to "purge" the compressed air since it has nowhere to go once the throttle body closes. it keeps the system alive and well basically.
if yours was broken and was not "blowing off" you would have noticed extreme bucking and very sensitive throttle response as the pressurizes air would always need an evacuation route when under low-closed throttle conditions. you would have posted up about that before a destroyed compressor if that was the case.
something annihilated your compressor wheel/housing, but it wasnt surge.
Old Oct 25, 2010 | 08:08 AM
icemans2k02's Avatar
yea something doesnt make sense. Wouldnt the belt have broken or been torn? or you would hear a skretching sound from the belt slipping since it would spin backwards?
Old Oct 25, 2010 | 05:28 PM
chris_barry's Avatar
Last compressor wheel I saw with that type of damage had eaten a rag that a helper in the pits thought it would be useful to stuff up the inlet piping while he had the air cleaner off.
The intercooler was filled with stuff like fine goose down that used to be the rag.
TraxxofAOT
May 14, 2015 07:42 PM
financedirect
Nov 25, 2009 10:13 AM
el10034
Jul 22, 2007 01:36 PM
Sideways
Mar 18, 2007 05:50 AM
nownor
Sep 3, 2002 02:32 PM
