Comptech fuel hose
Old Sep 20, 2016 | 04:45 PM
edumak's Avatar
Default Comptech fuel hose
The fuel hose on my Comptech sc has a lot of small cracks, so I think it's time to change it. The part number seems to be "6 rail to fpr fuel line 30" according to the check list. I was wondering if that's for the whole assembly or is that just the hose itself? Is the only way to order it is by going to ct-engineering and contacting them about it?
Old Sep 28, 2016 | 01:16 AM
edumak's Avatar
I emailed ct-engineering and the only response I got back was the price of it. After that, they got quiet and won't call back either. I called around some of their authorized contacts and they either don't have it, or it'll take months to get. I'm pretty disappointed to be honest.
Anyone know where else I can order this?
Old Sep 28, 2016 | 04:58 AM
CoolGuy094's Avatar
Aren't the fittings on the end of this hose just a standard barbed push-on? Can't you just go buy 100 PSI minimum rated fuel injector hose from Autozone?
Old Sep 28, 2016 | 05:02 AM
CoolGuy094's Avatar
My hose actually sprung a leak it got so old and degraded like yours is. I just pulled the hose off, removed the fittings from both ends (they were just -6 AN barbed push-on fittings), took the fittings to Autozone so I knew I was getting the right diameter hose for them, and bought a length of replacement fuel injector hose. They sell it by the foot and its like $2. Just make sure the pressure rating on the hose is greater than 100 PSI (which is like 7 bar).
Old Sep 28, 2016 | 05:43 PM
edumak's Avatar
Nice! I will definitely do that this weekend when I have time. Were there any gas left in the line when you took it out?
Old Oct 3, 2016 | 03:25 AM
CoolGuy094's Avatar
Yes, there will most definitely be gas left in that line when you remove it (likely pressurized as well). Stick a few rags under it and in/around the area when you remove the line.
scorchza
Jul 10, 2007 11:50 AM
elusiv
Aug 6, 2006 11:31 AM
modifry
Oct 25, 2003 08:13 PM
Fastrack
Oct 25, 2003 01:28 PM
AusS2000
Oct 19, 2003 09:58 PM
