Comptech SC
Old May 9, 2011 | 03:04 PM
jit13's Avatar
Default Comptech SC
How do you get the bolt off to drain the oil ? whenever I loosen it the return line moves with it (worried it might tear)
Old May 9, 2011 | 03:39 PM
donaldmejr's Avatar
The bolt should not have to come out just the hose with its fitting. Just hold the NPT to JIC fitting with one wrench and loosen the fitting that has the hose attached to it. Oil will come out of the bolt/fitting I hope your talking about.
Old May 9, 2011 | 03:48 PM
jit13's Avatar
Ok thanks
Old May 13, 2011 | 05:43 AM
Drkphnx's Avatar
This^^ Plus be careful to make sure you dont loosen the line at the blower. After you are done, make sure everything is nice and tight and u got no leaks. I had a shop do my oil change once and they didnt hold the line. It loosened from the blower and had a slow leak. I noticed when I checked my oil a week later and I was down 2 quarts!!! I tightened it back up and all is fine. Escept my cross member bar and everyithing around the lower end of the blower is covered in oil. time for a thourough engine bay cleaning lol
s2konroids
Aug 28, 2018 08:25 PM
SIIK2NR
Jun 16, 2015 08:19 AM
mwd473
Oct 1, 2006 06:03 PM
jdmdohcpower
Oct 31, 2004 04:45 PM
KenGPW
Aug 3, 2004 10:08 AM
