Comptech SC and Starter
Old Apr 3, 2013 | 01:01 PM
RedSunS2K's Avatar
Default Comptech SC and Starter
I think I already know the answer to this question, but and I'm hoping I'm wrong. My starter is starting to grind when turning on the car.
Do I have take off the supercharger in order to remove the starter? It's such a PITA. If I can change my starter without touching the SC I would be so happy.
Old Apr 3, 2013 | 01:07 PM
liquid_helix136's Avatar
Is this the terrible "gear grinding" noise when you first turn on the car, particularly in colder weather? Doesn't happen when the car is warmed up.
Old Apr 3, 2013 | 03:37 PM
soulicious's Avatar
If you can get to the upper starter bolt without completely removing the blower bracket, then you should be good. If I recall correctly, you will need to remove one of the alternator bolts so that you can swing out the alternator.
Old Apr 3, 2013 | 04:44 PM
RedSunS2K's Avatar
Yup, that's the one.
Old Apr 3, 2013 | 05:17 PM
s2000Junky's Avatar
You do not need to remove the SC or mount plate, but you may need to loosen it so you can shift the one intake end up out of the way, obviously removing two of the bolts on the other side will need to be done to swivel it up. You will definitely need to remove the after cooler to access that starter bolt and really make room to be able to remove the alternator and get to the starter itself.
Old Apr 4, 2013 | 07:03 AM
RedSunS2K's Avatar
Ohh maybe it will be easy since I have a custom setup. I don't run an AC.
suprfunguy
Sep 13, 2006 02:44 PM
General Kratos
Jul 23, 2006 10:15 PM
bgbfflochp
Apr 29, 2004 12:00 AM
rocketman
Feb 9, 2002 08:29 PM
DJ Qube
Jul 27, 2001 10:36 PM
