comptech SC with VAFCII
Old Dec 29, 2008 | 11:36 AM
r_duff's Avatar
Default comptech SC with VAFCII
Hi everyone, i got a VAFCII from a board member, and im wondering how to install it with the comptech ESM (not sure if you splice before the ESM or after ). Thanks in advance!
Old Dec 29, 2008 | 02:46 PM
tightcrap7's Avatar
change ESM to the "synapse missing link" one. its mechanical as oppose to electrical. and try to get a boomslang or frog harness, it saves you the hassle.
Old Dec 29, 2008 | 03:58 PM
r_duff's Avatar
the esm is already soldered in. Spending 160 bucks on another harness, AND removing the ESM, AND buying and installing the 'missing link' is not worth the trouble of just soldering in the vafc wires
Old Dec 29, 2008 | 03:59 PM
MINES13's Avatar
except the fact that the ESM wont even work because the VAFC adds and removes fuel by increasing and decreasing the MAP voltage. The ESM clamps the map voltage at around 2.92 volts electronically and due to this, the VAFC will do nothing in boost. You have no choice but to go the missing link route and ditching the ESM.
Old Dec 29, 2008 | 06:56 PM
s2k aok's Avatar
i have a non-ac pending install and i am also going to be running a vafc (to trim the excess fuel). the kit i have is an old one which did not come with an esm box but had something like a check valve. this comptech kit has been updated since then and i'm not sure about the reliability of the check valve or if adding this cheap synapse missing link should be a part that i should purchase. anybody have experience with the comptech non-ac check-valve versus the esm?
missing link $60
http://www.racingworks.com/missinglink.htm
Old Dec 29, 2008 | 07:15 PM
s2k aok's Avatar
yeah i think i'm going to order the SYNAPSE MISSING LINK. thanks for the info works out much better for me rather than an esm.
Old Dec 29, 2008 | 07:39 PM
s2k aok's Avatar
i searched through all the venders average price for the missing link was 'bout $60 but the damn sites were claiming 1lb, 2lbs, even up to 4lbs for shipping on this item. what a bunch of dishonest crooks! shipping was going from $10 to $25 for this little tiny item. i finally found a somewhat local vender (fl) and they gave the ups ground shipping for FREE. nipponpower.com ftw!
now take a look at that pic, does that really look like four pounds? not even four ounces and that's including packaging.
Old Dec 30, 2008 | 12:09 PM
dans2k's Avatar
VAFC is Mickey Mouse. Please do your self a Favor and Get the AEM EMS.
r_duff
Dec 29, 2008 07:24 PM
s2000Junky
May 9, 2008 11:15 AM
spa2121
Jun 15, 2006 09:10 AM
superhonda03
Sep 24, 2005 02:25 PM
pjonkheer
Apr 21, 2004 07:20 AM
