cooling discussion
I can hopefully add another data point to this thread in a few weeks when I run my car at Sebring. This will be the setup:
PTUNING Turbo Kit
PTUNING Front Mount
PTUNING Oil Cooler
Mrsideways 3" Dual Pass Radiator
14" SPAL Fan
I will very closely be monitoring both coolant and oil temps.
PTUNING Turbo Kit
PTUNING Front Mount
PTUNING Oil Cooler
14" SPAL Fan
I think a bottom mount turbo like the Ptuning setup and SOS help with heat a lot. An oil cooler is a must. I think a larger radiator would also help with spal fans attached. There was a guy on the forums called Metros who tracked his ptuning car successfully and here is what he had to say about his setup:
From personal experience: The PTuning kit held up to track use beautifully. I ran the kit with stock radiator and Koyo radiator, as well as the setrab oil cooler that's part of their turbo set up. With stock radiator temperatures were fine upto around 75* ambient temperature. At that point if I continued to push the car the coolant temps would start to get hotter than I wanted (215-219*). I upgraded to the Koyo radiator and the temperatures stayed below 215*. I also learned that by leaving the heat on while tracking you could expect around a 10* difference consistently. Meaning if they peaked previously at 215 then they wouldn't go any higher than 205 while heat on. If you're running the greddy turbo kit then you're more or less out of luck. We had a local running the greddy kit that had upgraded radiator and oil cooler and still couldn't keep temperatures in check. The main problem being the greddy turbo only uses oil for cooling. His oil temps would spike up to 300 quickly and end up shortening his track time each session.
Some vids: YouTube Mxmetros6
http://youtu.be/mXQf4VCPZF0
My 2 cents, if you're building a serious FI track s2k and trying to run FAST laps, you probably need a v-mount setup. Why even waste your time messing with a FMIC? That's my opinion at least. I'm not saying FMIC's can't/don't work, just there's a lot of useless "so and so's car was fine" floating around but little concrete data. Regarding the video you posted, he's clearly taking it easy on his car on Summit Main letting off on the front straight and other areas.
I track my car, I have a built engine and run 26psi boost on a gt3076hta turbo. I run a 25row oil cooler and a dual pass rad. Water stays around 88c on track without the need for fans turning on. Oil gets to about 100-110 but have now got a oil temp switch in the oil line that I have wired to run a van attached to the oil cooler, I'm happy as long as oil doesn't get over 115-120c. I have literally spent a fortune to get the cooling system right.
Vmount setups seem stupid....the one thing you don't want is air exiting from under the car as it causes lift and a vmount forces it out underneath.
I run a vented bonnet too. I have a build thread on the UK forum so you will see the work I have put in to it.
PTUNING Turbo Kit
PTUNING Front Mount
PTUNING Oil Cooler
14" SPAL Fan
PTUNING Turbo Kit
PTUNING Front Mount
PTUNING Oil Cooler
14" SPAL Fan
Sorry bro.
It's worth a shot since your kit comes with a FMIC. For those getting an SOS kit, their v-mount setup is quite affordable imo and SOS said their kit run w/ a/c w/ the new condenser didn't really affect water temps much which is very impressive.
You don't have to have a vmount. I good flowing dual pass with proper air flow will work fine.
As for as coolant vs distilled water, you can absolutely do that. My car is running mostly distilled water, maybe half gallon of Honda blue, and one bottle of water wetter. I have an oil cooler and Mr.Sideways dualpass radiator (link below) with a single 14inch fan. I don't track my car but I built it to be tracked, daily'd, and beat on. Closes I've done to tracking, which I do plan on changing, is running at the Dragon. Not once did my car come close to overheating while driving it. There is also a guy in town that does track with a P-tuning kit that also has no issues with overheating.
http://www.mrsideways.com/s2000radiator.html
Weight of the cooling system I'm not sure about. If it were by build, I would worry with it and try to loose weight else where. On another note though, being a dedicated track car, you most likely won't have the heater core installed so you'll loose weight there from the core and hoses being gone plus less coolant.
Beating on the car on the street does not even remotely compare to beating on the car on track, with a driver who can really push it. You cannot really make a statement of, "You don't have to have a vmount. I good flowing dual pass with proper air flow will work fine." based on a street car (which is really what you have).
Somebody gets it! \/
I guess there are two different setups then. You can enjoy a few track day events with upgraded cooling mods as I and others have stated with some reliability. Everyone is focusing on track only cars with serious racers that beat the piss out of the car. Not everyone fits into that category.
