CP Piston Clearance
I'd really appreciate your opinions on the piston clearance for the CP 11.5 stock bore pistons clearance.
The paper that came with the pistons says 0.0030 and my mechanic recommended 0.0035
the car is stock with the exception of the CP pistons + BC Rods & I'll be using AEM ECU
thanks alot in advance
Ali
Ali
S2000 sleeves are made out of frm, the only aftermarket piston you can run that I can think of off the top of my head are mahle frm pistons. I wouldn't even mess with frm stuff and have either benson or darton sleeves installed
-chris
-chris
the problem is that the pistons spec sheet does not state the power which this clearance is used with.
is it true that with higher power you need more p2w clearance?
could it be that the higher compression pistons, comes with tighter recomended clearance because it is assumed to be ran on NA setups?
