CP Piston Clearance
Old Sep 19, 2012 | 03:50 PM
buzz944's Avatar
Default CP Piston Clearance
I'd really appreciate your opinions on the piston clearance for the CP 11.5 stock bore pistons clearance.
The paper that came with the pistons says 0.0030 and my mechanic recommended 0.0035
the car is stock with the exception of the CP pistons + BC Rods & I'll be using AEM ECU
thanks alot in advance
Ali
Old Sep 19, 2012 | 04:19 PM
miguel329's Avatar
Cp pistons will not work on a stock s2 frm sleeves. You need new sleeves
Sent from my PC36100 using Tapatalk 2
Old Sep 19, 2012 | 07:31 PM
vduber's Avatar
S2000 sleeves are made out of frm, the only aftermarket piston you can run that I can think of off the top of my head are mahle frm pistons. I wouldn't even mess with frm stuff and have either benson or darton sleeves installed
-chris
Old Sep 20, 2012 | 02:16 AM
buzz944's Avatar
yeah the machine shop is installing cast iron sleeves as we speak
so the pistons are good to go
Old Sep 20, 2012 | 03:34 AM
Sobe_Death's Avatar
Always go with what the piston manufacturer suggests for clearance. Their materials, their design, and their testing have all been taken into account when they include that spec.
Old Sep 20, 2012 | 04:25 AM
burnin_ruberi4's Avatar
the problem is that the pistons spec sheet does not state the power which this clearance is used with.
is it true that with higher power you need more p2w clearance?
could it be that the higher compression pistons, comes with tighter recomended clearance because it is assumed to be ran on NA setups?
BoostedE21
Oct 27, 2015 06:41 AM
ack5252
May 17, 2012 08:14 AM
Daniwmk
Feb 26, 2010 01:09 PM
dsddcd
Aug 5, 2009 06:30 AM
GSRacer
Dec 2, 2002 08:27 PM
