Crankcase breather valve
Originally Posted by DFWs2k,Sep 30 2010, 10:20 AM
Q: white smoke is oil burning?
Originally Posted by sfrost2287,Sep 30 2010, 12:00 PM
the only thing Im worried about is not finding out what caused the problem, then when I pay all the money to get built it will just happen again...
^ what are some common causes of detonation, and how do I find out exactly what caused the problem? could it be a faulty knock sensor or anything like that? I have thus far heard:
1: bad tank of gas
2: improper tuning once turboed
3: bad injectors
4: bad fuel pump
and a few others I think..
but how can I definitively find out EXACTLY what caused it?? Im just super nervous and afraid its gonna happen again after I dump gobs of money into the rebuild. Thanks guys
1: bad tank of gas
3: bad injectors
4: bad fuel pump
Its difficult to pinpoint what caused the detonation becuase there are half a dozen or more ways, assuming your tuner has taken in account your modifications and set things up appropriately. Making sure you are running a good afr in the 11-12 range and retarding timing appropriately to boost level and load/heat. Making sure all of your OEM systems are working properly is the first step. You can run too rich and cause detonation also, or fuel wash your pistons creating comp loss and bearing failure.
I'm a big proponent of water/meth... or just meth injection. It won't protect you against a fuel wash conditions, but depending on how its integrated into your tune it can add a significant safety barrier, protecting against typical unforeseen variables. You don't have to use it to make more power, but to run a good tune and then use it as a safety buffer, so if you ever do get a bad tank of gas or run too hot IAT you likely won't have detonation killing your motor.
